Other Cleaning out a pc
Discussion in 'Hardware' started by MarkW7, 22 Feb 2009.
  1. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    I tend to use a very soft paint brush (art type) to gently remove the dust off delicate parts and onto the case frame, then use a vacuum to pick it up. I should really get some canned air too as it's a lot easier to clean heatsinks properly with those, especially graphics card ones!
  2. O O 7
    O O 7 What's a Dremel?
    7 Dec 2008
    Any HDDs which are "on" (i.e working) would be destroyed if they "fell". All is lost for eternity....
    unless you pay you, your mom and your dads life savings to get it repaired! :naughty:
  3. Snuffles
    Snuffles Dreamy Mammoth
    24 Feb 2009
    The straw on the can gets into a lot more crannies than a giant vacuum nozzle. A good mixture of both will clean it out nicely. Just dont let the vaccuum get close to anything inside the case.
  4. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    http://www.ebuyer.com/product/129597
    there what i use, realy big cans for the money.. wait THEY WAS £8 WHEN I GOT MINE!! MOTHER F%&KER!
  5. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    £10 postage! These people must be mad.
  6. Otis1337
    28 Nov 2007
    order 2-3 can and use "supersave" postage you nab:thumb:
    its like £4
  7. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    had a look at mine today and decided it needs cleaning - the mixture of dust and nicotine tends to create a sticky substance....yuk
    i think i'll just buy compressed air because i have incredibly bad luck with this kind of thing
  8. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    Shop-Vac on blow works pretty well too. Outside.... I also use my Dyson, the crevice tool works pretty good for the tight spaces. Make sure if you're using a bagless vacuum to empty out the canister first, the crap swirling around creates static, I've never had an issue with static discharge on any of my components, but I don't go banging around in there either.
  9. B3CK
    B3CK Minimodder
    14 Jun 2004
    At my pc repair shop we use compressed air, from cans and compressor. Shop vacs, and the small low power hand vacs that have the brush attachment.
    We only really use the handvac with brush for nice cases on the outside bezel crevices. Canned air for light dust jobs. For heavy we use a compressor. The compressor gets changed alot depending on what air handle we are using, as one handle has a larger outlet hole then the other. We, (I), broke a mobo cap off of an old mobo with the compressor on high psi setting using a small holed handle. So just fyi, watch out there. (I now use 25-35 psi on small holed handle, 60-75 psi on the large handle, and when it's up high, i don't get very close, as in about 2feet away from board).
    We have a homemade cardboard box, very very large, that we attached to one of our shop vacs that use as a booth for the really dirty ones, think of it as the cheap mans negative air pressure booth.
    And if it is extremely dirty, take that sucker outside to blow it off, and stay away from my car with it!
  10. mclintox
    mclintox Eat cheese!
    15 Nov 2008
    Clean out your vac,reverse to blow if you can,switch on,get a 1 1/2" paint brush if you have one and blow it away.Electronic/computer components are far hardier than they used to be,static is not really a problem,unless your wearing nylon and are kniky that way! ;-)
  11. SiG
    SiG What's a Dremel?
    3 Dec 2007
    Vacuum cleaner, make-up brush, isopropyl alcohol and cotton-tips.
    Vacuum cleaner nozzle never makes contact with components - it has sufficient suction to collect debris and the make-up brush enables me to dislodge any hard to 'reach' dust.
    Isopropyl Alcohol is more relevant for when I clean PCB terminals, but is still rather valuable when it comes to removing some of the more 'persistent' items such as labels an such. My absolute favourite feature of isopropyl alcohol is that it evaporates in a matter or seconds, which makes it just that little more versatile.
  12. UrbanMarine
    UrbanMarine Government Prostitute
    7 Aug 2008
    I break everything down and use a air compressor to blow out all the dust. I used micro fiber rags to wipe down the case. I get roughly 95% of the dust out each cleaning.
  13. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    i use a vacuum cleaner's brush attachment unless your being a complete tit you wont break anything
  14. Nicb
    Nicb Let's discuss among ourselves
    12 Nov 2008
    You guys/blokes will probably freak out on this one. Every once in a while I break down my computers and wash them in the sink with water, MB, fans, GPU, etc. Dry them and set them in the garage to air dry for that oh so brand new look. Never have had a problem in the last few years of being brave enough to do it. Once I dropped my cell ph in the ice chest full of beer, took it a part and let it air dry. Put it back together and it worked. So I said hey........ my PC?...... Why not!
    But most of the time I use a air can. I advise not to be like me, but thought you might like to know PC parts can handle a good cleaning.
  15. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    The PSU too?
  16. Dozer42
    Dozer42 What's a Dremel?
    22 Feb 2009
    We fix PCs professionally. Here's how we do our cleanings.
    Canned air is better than nothing, but it's nothing like hitting the computer with a proper anti-static vacuum cleaner.
    We use DataVac 3s, vacuum out all the dust we can without touching any electronic components (pc boards, memory, etc...Anything that could be fried by static electricity)...
    We show the customer the results, and they go, "Oh! That looks much cleaner! I can't believe there was that much dust in there!"
    Then we take the hose, switch the vacuum to blower mode, put on a small nozzle (half centimeter or so?) and blow the thing out.
    HUGE, HUGE amounts of dust come flying out everywhere (do this outdoors). After a good ********, we'll take a paper towel, wet it with alcohol, and wipe off the bits that still have a fine layer of dust.
    It's very rare that vacuuming out dust will FIX a problem with a stock computer (like crashing), but all the dust certainly degrades performance, and the life of the computer in general.
    And nothing is worse for the computer than smoke. Smoke KILLS computers and hard drives. (Even dog/cat hair isn't as bad).
    YMMV
  17. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    I disagree. My old Athlon XP had never been cleaned from dust between the CPU fan and the heatsink. It started BSODing a few years back. Added a rear case fan and it worked for a year without a hitch. Then added a front case fan. Again it worked fine for a year. Then I cleaned the CPU cooler and the temps dropped with over 10°C and since that it has never had a crash.
  18. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    Sorry Maltor, but I lol'd :)
    I just use q-tips and kleenex, I've never had enough dust build up that it merits a vacuum cleaner. Mind you don't use acrylic/synthetic cloths - static charge, et cetera.
  19. azrael-
    azrael- I'm special...
    18 May 2008
    Two words: Dirt Devil (or something like it)
  20. inzane86
    inzane86 engineer with an axe
    15 Jan 2004
    I use canned air or compressor, with a paint brush. Isoproanol and q-tip for sticky stuff.
    It's a good idea to ground yourself, your tools and your working place.
