CNC uber router - Yay, update!
Discussion in 'Project Logs' started by kong, 7 Sep 2003.
  1. :: Phat ::
    :: Phat :: Oooh shakalaka!
    7 Jun 2002
    I may have an ikle jobbie for you sometime soon :)
    I need someone with a CNC machine to make me a single link for a robot tank tread so I can make a mould out of it and make some tank tracks for a forthcoming project :) I'll design one and get in touch with you :thumb:
  2. kong
    kong cnc-guy
    24 Feb 2002
    Oops, I keep forgetting to take piccies! I have made the router mounts today, and have the Makita router mounted. I had a test run with a borrowed transformer and that thing is sooo quiet! Just waiting for my dad to drop off a big yellow box 'o lurv so I can run it properly. Piccies tomorrow.
    Lupine, nice link, that spindle must be packing some major HP to cope with that speed of cut!
    Phat, hmm, sounds interesting!
  3. Lupine
    Lupine What's a Dremel?
    18 Dec 2003
    Hmm... A PC on Treads? Not codenamed Project : Challenger 2 is it? :lol:
  4. kong
    kong cnc-guy
    24 Feb 2002
    Well guys, time for a quick update! I must learn never to buy an rc nitro car before my projects are completed!!
    I have taken delivery of the Makita RD1101 router, and wow, what a machine. Quiet as a hairdryer, Nice!
    Oh yeah, here's the socket for the power, coz I forgot it before! Fortunately I was able to take this one off of the d-handle assembly of the router, which meant I did not have to take the router appart to stick on a different plug/lead.
    Yep, that thing's getting waay dusty! I cut the slots in the marine-ply sub table today which will form the base of a T-slot table.
    And more dust:
    You can just make out different coloured slots. I changed the design half way through cutting, to give me fewer slots, so only half of them are cut to full depth. Wish I'd made my mind up before cutting them all, but nevermind!
    Anyhow, a quick clean up, and a nice coat of polyurethane varnish should finnish that off until tomorrow.
    Oh damn, I knew I forgot something! Before I secured the plywood down, I ran some 1/4" thick angle ali across the bed for added support. Hopefully it should stop the ply from dipping over time.
    Hehe, anyone reading cnczone will see I just copied/pasted this post! I'm gettin' lazy!
    486hawk likes this.
  5. 486hawk
    486hawk What's a Dremel?
    18 Jul 2003
    I like! :rock: Makes me want to go out and build my own.
  6. Enak
    Enak Also known as Kane
    23 Jul 2002
    :jawdrop:
    Looking real good!!!
  7. Lupine
    18 Dec 2003
    What are those spiral grooves around the router, and why don't they show up in the pic with the aluminium angle bars across the chassis?
    Otherwise, looking very nice. :thumb:
  8. The_Sub
    The_Sub What's a Dremel?
    16 Nov 2003
    My guess would be that the spiral groove are part of the original bit depth adjustment. As in when the router was attached to the base that comes with it from the store..
    Awesome cnc Kong!!!
  9. kong
    kong cnc-guy
    24 Feb 2002
    Yep, the_Sub is right. They are part of the depth adjustment on the US style fixed base routers. You don't see them in the other photo, coz it's a different router! Look back to when I first cut the router mounts using that old red router...you'll see the old B&Q router mounted, and is that one which has no spiral grooves unlike my new Makita :D
    Quick update - I have screwed down the aluminium table top today, and began cutting grooves, but snapped my last 3mm cutter :waah: It's ok though, I ordered more today so they should be here tomorrow!
  10. SoreGums
    SoreGums What's a Dremel?
    16 Jan 2004
    Totally Awesome
    I just spent the best part of a few hours reading from page 1 to here and this is totally awesome!
    Can't wait to see the video.
    I was looking for the update to Orac, but found this instead.
  11. Otto's
    Otto's What's a Dremel?
    16 Jan 2004
    :rock: cool and work really well
  12. Gedron
    Gedron What's a Dremel?
    31 Oct 2003
    This project dared to fall off the front page.. BUMP I say!!
    Any progress Kong?
  13. kong
    kong cnc-guy
    24 Feb 2002
    Hehe, I have been busy this week, I have got the ali top on, and havbe run the oruter over it a couple of times. Still got the slots to cut out yet though! So many things, so little time!
  14. Gedron
    31 Oct 2003
    Pah! Sleep when your dead :naughty:
  15. kong
    kong cnc-guy
    24 Feb 2002
    Jeez, I need sleep now, see, I can't even type!
    "and havbe run the oruter over it a couple of times" oops :D
    NiHiLiST likes this.
  16. Gedron
    31 Oct 2003
    now Kong, I've seen you type before... I dont think lack of sleep is the issue :worried:
    Just playing bud. Keep up the good work :thumb:
  17. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    looking great man :)
  18. chimp
    chimp What's a Dremel?
    18 Jan 2004
    Can't think of a better project for my first post. Excellent Work
    May have some work for it when it is finally finished. :clap:
    Tempt to try myself, but no space for sucha beast :waah:
  19. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    Caffeeeeeeeeeeiiiinnnnneeeee
  20. Lupine
    18 Dec 2003
    Any more progress on this Kong?
    Or have you been too distracted playing with the aforementioned nitro powered R/C car?
