News Component shortages halt Oculus Rift production
Discussion in 'Article Discussion' started by Gareth Halfacree, 24 Feb 2014.
  1. Gareth Halfacree
    4 Dec 2007
  2. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    Short on small screens, I presume?
  3. rollo
    rollo Modder
    16 May 2008
    Will Occulus rift ever leave development and actually be a commercial product. Does not appear to be happening this year.
    Second hand sales will probably take the price north of $400 I'd imagine.
  4. Gareth Halfacree
    4 Dec 2007
    They haven't said, but that's what they were running out of a while back: since mobiles moved to higher-resolution panels, low-resolution panels have been harder to source. It'd be my best-guess for what they've run out of, yes - and they may end up just ditching the original design and holding out for Crystal Cove instead, providing they've got enough dev kits to provide to actual developers (rather than anyone waving $400 at 'em.)
  5. Cthippo
    7 Aug 2005
    Wonder how many they would have to commit to buy in order for someone to produce the screens they need. Of course, since this isn't intended to be the actual commercial product, I guess they won't be ordering tend of thousands of the low res parts. Still, bad timi9ng, hope they can overcome it.
  6. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Probably. The reason the DK1 switched from the 5.6" panel used for the prototypes to a 7" panel was that there were not enough of the 5.6" panels in existence to produce enough devkits to fulfill the kickstarter orders.
    The mobile hardware lifecycle is brutally short, usually around 6 months from start of production to end of production and selloff of excess stock. If you don't get your order in at production time, then you're relying on there being sufficient excess. At the size Oculus were when they chose the 7" panel, they were an order of magnitude or two away from being big enough to actually get the time of day from manufacturers and order a new production panel (along with other issues like everyone building MIPI DSI panels instead of LVDS for mobile devices).
    Now they can probably assume at least 100,000 units for the DK2 and CV release, and have a massive tide of press and expectation to bank on for future releases, so they can place a small order for the desired panel in advance of production and actually get it once the main buyers (Samsung, Apple, etc, big tablet and phone manufacturers that order millions or tens of millions of units) get their orders fulfilled.
    Assuming the DK2 and CV are announced significantly prior to shipping (i.e. when the hardware is finalised) I would bet that the panel it ships with will be one that has just started shipping in a phone/tablet at around the same time as the announcement.
    Speculation ahoy!
    With the Crystal Cove prototype using OLED for it's fast switching time, I'm guessing one of Samsung's AMOLED panels will be used in the DK2 & CV. The Crystal Cove used a Pentile arrangement (because that is what is available), but because a HMD doesn't have the lumen output requirements of a phone or tablet a proper RGB-stripe layout is vastly preferable. Look out for Samsung releasing a phone or tablet with an AMOLED panel in the 5.6"-6" range and an RGB-stripe subpixel layout, because there's a pretty good chance that'll be the Oculus panel.
  7. Nexxo
    23 Oct 2001
    Yeah, and I'd be buying...
  8. Cei
    Cei pew pew pew
    22 Mar 2008
    They need to stop releasing vapourware. Rift is becoming synonymous with "dev kit", and every trade show seems to have yet another revision that is no closer to a consumer launch. They're rolling in funding, so what exactly is the holdup? If they keep messing about like this, they'll start losing support and hype.
  9. specofdust
    specofdust Banned
    26 Feb 2005
    You and everyone else with enough money to get one and upgrade their PC.
    Unlike 3D, I'm thinking VR is going to be huge.
  10. Cthippo
    7 Aug 2005
    By the sound of it they're waiting on developer support and parts, both of which are out of their control. They've demonstrated proof of concept, but until games are coded to take advantage of the headset as both an input (sensing head position) and as a display then it's largely a non starter.
    Likewise, if they can't get the parts to build the headsets, then it's not happening. As others have said, they're not placing big enough orders (yet) to get a manufacturer to build a production run just for them, and currently no one builds the screens they need.
    All that said, I think this is well beyond "vaporware" and hopefully the company has enough resources to hold on until the developers get on board and they are able to start placing production sized orders with their vendors.
    There is absolutly no reason that this VR implementation shouldn't include 3D by default. The hardware is there, it's just a matter of the programming and computational grunt to take advantage of it.
    Oh, and missed seeing you around, Spec.
  11. specofdust
    specofdust Banned
    26 Feb 2005
    There is one good reason, and that's graphics power. From what I understand, the rift already requires you to be at about a minimum of 90 fps to have a smooth stereoscopic experience. How many graphics cards do you know that can do two screens of 90 fps at 1920x1080 in modern games? 3D, as I understand it, requires even more power, and so unless we all want to start running quad Titans, then I reckon 3D remains on the backburner for the first while.
    edit: Also, you too :)
  12. sandys
    sandys Multimodder
    26 Mar 2006
    The rift only has one screen and would do 960x1080 per eye if it was 1080p plenty of setups could run that in 3D, depending on game you may only need 1 beefy card. The screen it launched with was 1280x800 (640×800 per eye) , plenty of systems could monster that in 3D.
  13. SAimNE
    SAimNE What's a Dremel?
    23 Oct 2012
    actually i'm pretty most cards with a mid-high end graphics card could handle occulus rifts 3d. it's not like it's running at a high resolution, it's 1080x960 per eye which is just a standard 1080p screen, so the resolution is never going to be the bottleneck. not sure about the 90fps thing, but if you didnt push the new games into ultra you could be able to get reasonably close results in new games with just an r9 290.
    tho hopefully the rift will use a resolution even higher than 1080. thinking 1440 would be nice.... 1600+=godly
  14. Nexxo
    23 Oct 2001
    You make it sound like running quad Titans is a bad thing. :p
    Legend of Zelda on Occulus Rift: SO WANT.
    BTW don't they have internet access on oil rigs?
  15. specofdust
    specofdust Banned
    26 Feb 2005
    And here we have a man who's wife pays the electricity bill....
    They do indeed, but they also make me do work out there for some reason. I'd give oil rigs 2 stars at most, the food's OK but the swimming pool is nowhere to be found and there aren't any women on them.
  16. Nexxo
    23 Oct 2001
    Outrageous! That's almost as bad as the NHS (except that the food is worse. On the upside, there's plenty of women, but they're all too tired and so am I)!
  17. Guest-16
    Guest-16 Guest
    More than likely. When you're competing against the buying power of smartphone makers, you're pretty far down the pecking order.
