Hardware Computex 2009: Hardware Preview
Discussion in 'Article Discussion' started by Sifter3000, 1 Jun 2009.
  1. mclintox
    mclintox Eat cheese!
    15 Nov 2008
    "MSI GTX 260 Lightening graphics card" Lightening?
  2. pimlicosound
    pimlicosound What's a Dremel?
    7 Sep 2007
    I love you guys.
  3. Omnituens
    Omnituens What's a Dremel?
    5 Apr 2006
    did i read that right, they are updating the GTX 275 as well? (im at work and the IE doesnt render the page well :( )
  4. flibblesan
    flibblesan Destroyer
    27 Jul 2005
    I really like the look of the In-Win Maelstrom case. Hopefully it will sell for a reasonable price. My Coolermaster Centurion needs replacing due to scratches.
    I also like the Asus OC Station. The display is really cool.
  5. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    You won't see onboard GPUs on any P55 motheboards. You'll have to wait for the G55 variants.
  6. Gremlin
    Gremlin What's a Dremel?
    31 Aug 2008
    I -love- that gigabyte are making the AMD bios hack available on all dual bios SB750, and I assume SB710 boards even though it wasn't mentioned in the article, since it has ACC and its the chipset on the 785G board shown :)
  7. ch424
    ch424 Design Warrior
    26 May 2004
    (and vdbswong)
    Oops, should have read the article properly, sorry...
  8. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    The codename you want in Havendale. The GPU will be integrated onto the CPU.
    That's a good question. If those are 3.0 ports, they would need to be handled via an add in chip. I think NEC is the only manufacturer with a 3.0 HC at the moment. I didn't see anything obvious in photos though.
    If those are 3.0 ports, then I am also curious about BIOS support for the 3.0 ports.
  9. Elton
    23 Jan 2009
    Glad to see both MSI and Gigabyte making good P55 boards.
    But I really do hope they come out before the end of summer...
  10. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    All those so called "industrial leaders" still manage to put a 300 year old FDD controller on the boards. Yet they come with all kind of 'new' funky stuff to slam on the motherboards. I bet they get payed by Sony to put on FDD controllers since Sony is the only Floppy Drive manufacturer left on this earth, they probably have a stock of 1.2 billion FD's in a gigantic warehouse. Do like Atari did with their E.T. cartridges and dig a large hole in the Mexican desert, drop the drives in there and forget about it for ever and beyond...
  11. Elton
    23 Jan 2009
    Well, Sony has to make some kind of money, I mean after all the piece of craps they've made.
  12. Splynncryth
    31 Dec 2002
    Thre are these things called Super I/O chips. They come with a lot of different legacy controllers on them like floppy, serial, LPT, PS/2, and stuff like that. They also have hardware health monitoring, POST code port 80h functionality and other handy things on them.
    If you are working with an older OS like XP or server 2003, a driver floppy is an easy way to get your storage driver loaded. Both installers tend to be picky about USB floppy drives. Both OSes are used enough for OEMs to just break out the floppy port they are already paying for.
    I can think of a few other reasons an OEM might decide to break out the floppy on a super I/O chip, but these tend to be for disaster recovery or debugging.
    You don't have to use it, the controller is already part of a chip used for other stuff, and the port doesn't take up that much space. What would be a good alternative to the space used that isn't already there?
  13. Guest-16
    Guest-16 Guest
    Yes - everything with ACC will get it. 785G/SB710 and 790GX/GFX/SB750 boards should have the option eventually.
  14. Guest-16
    Guest-16 Guest
  15. Guest-16
    Guest-16 Guest
    No, no USB 3.0.
    ALL Gigabyte boards will get POWERED eSATA though in the future - eSATA ports will double up as USB and visa versa - ideal for external eSATA flash drives like from OCZ.
    MSI currently has this on its 790FX AM3 we reviewed (and didnt realise at the time), and will also push it on its own P55 boards too.
  16. wyx087
    wyx087 Multimodder
    15 Aug 2007
    for powered eSATA drives, will it work with existing set of eSATA portable drives?
  17. GigaMan
    GigaMan GIGABYTE UK
    30 Oct 2008
    We (GIGABYTE) feel that 24 power phase will be important.
    It may not seem like this now, but I will guarantee you that our competitor will follow – Why, because it is vital that the power phases switch power effectively.
    When we introduced 2oz copper, we were told the same type of story – no need for 2oz, it’s a waste of time etc… but now other manufactures are starting to introduce this, yet no one seems to be challenging them!
    I think that most people are under-estimating the P55 performance vs the X58.
    This is going to be very interesting and I’m excited and can’t wait for Bit-tech to release the performance result – we can always trust Bit-tech/CustomPC ïŠ
    GIGABYTE will originally only release SATA II and USB2.0
    The reason is because SATA III at the moment has no advantage in performance.
    The same for USB3.0, so for now, SATA II and USB2.0 will be standard
    GIGAMAN
  18. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    You would expect a representative from Gigabyte to know how to use punctuation and to use the correct name for SATA 6Gbps. :sigh:
    So, on one hand you say 24 power phases aren't important now but will be in the future and that's why you include them. In the next paragraph you say that SATA 6Gbps and USB3.0 aren't important now but will be in the future and that's why you DON'T include them.
    Make up your mind. :eyebrow:
Tags: Add Tags
