Graphics Cooler for ASUS GTX590
Discussion in 'Hardware' started by keith_j_snyder2, 10 Apr 2013.
  1. keith_j_snyder2
    keith_j_snyder2 What's a Dremel?
    22 Apr 2006
    One of m closest buddy has an ASUS GTX590 GPU & his temp. is running around 90degrees C which is quite hot. Please suggest a good after market cooler for his stock replacement.
    P.S- He lives in Birmingham so anyone lives closeby can suggest him something good.
    Thanks in advance.
  2. The_Crapman
    5 Dec 2011
    First thing you might want to try is taking the card apart, giving it a good clean and replacing the TIM and thermal pads. Here's a video with instructions on how to take it off: http://www.youtube.com/watch?v=LNNg3rbmiM0.
    Also make sure there's good airflow through the case and possibly upgrade the case fans. If that doesn't fix it the only option is water cooling, as there's no aftermarket air coolers for the 590.
  3. Shirty
    18 Apr 1982
    As Crappy states above, other than a spring clean his only other choice is to get his hands/card wet.
    siliconfanatic and The_Crapman like this.
  4. Guest-16
    Guest-16 Guest
    I have an almost new EK waterblock he can have for the price of shipping. The 590 I was gonna use it on broke :(
    It just needs new thermal pads, which are dead cheap. Bung it on a 120mm radiator with a cheap pump/res and you're job done.
    David likes this.
  5. docodine
    docodine killed a guy once
    10 Feb 2007
    is a 120mm rad good enough for a 590 though? maybe a thick one.. i'm pretty clueless when it comes to WCing video cards, especially exotic ones like the 590
  6. Guest-16
    Guest-16 Guest
    You're not likely to get suuuuuuuper temps but it'll be better than any air-cooler. A bit of fun at cheap cost. I've run a GTX 480 + CPU on a thin 3x120mm before.
  7. keith_j_snyder2
    22 Apr 2006
    Thanks for the video. I believe a thorough cleaning will sort his heating problem out. The chassis he's using is CM 430 elite.
  8. keith_j_snyder2
    22 Apr 2006
    Thanks for the generous offer but i don't think he's geek enough like us to assemble all by himself. Someone has to do it for him. But i need to talk to him first.
    Thank u all for your suggestions.
    :thumb:
  9. Abraxas
    Abraxas What's a Dremel?
    26 Sep 2010
    Just to confirm, is TIM just another name for thermal paste?
  10. docodine
    10 Feb 2007
    yes, thermal interface material = TIM
  11. keith_j_snyder2
    22 Apr 2006
    Guys he cleaned up the Cooler & the temp. dropped to 73 C! Thanks u all for ur suggestions.
