Hardware Cooler Master CM 690 II Case Review
Discussion in 'Article Discussion' started by Guest-16, 18 Feb 2010.
  1. Guest-16
    Guest-16 Guest
  2. okenobi
    okenobi What's a Dremel?
    3 Nov 2009
    Nice review. Hope you're feeling better Harry ;)
    Any chance of putting some more fans in??
    KIDDING!!!!!!!!!!
  3. Abhorsen
    Abhorsen Minimodder
    10 Apr 2008
    I was hoping this would make my case choice easier, but it hasn't :(
    Agreed it's got the looks and the features and the scope for more fans, but my other choice is the Lian-Li PC-P50 which is just as good to look at and has superior stock cooling, the question i've got to ask myself, is it worth getting the 690 II and spending the £20 difference on fans, or do i just get the stock Lian-Li!?
  4. frontline
    frontline Punish Your Machine
    24 Jun 2007
    Nice review and thanks for the pics of it with motherboard etc fitted :)
  5. xMathiasD
    xMathiasD What's a Dremel?
    15 Mar 2009
    Great ! :D - you guyz ROCK!
  6. Abhorsen
    Abhorsen Minimodder
    10 Apr 2008
    Hmmm Scan have it at £81 but it's awaiting stock. For £81 it appears a very good deal.
  7. Rotcrack
    Rotcrack Food Maestro.
    24 Jul 2009
    Looking good, spelling mistake though. :sigh: I challenge you to find it.
  8. Matticus
    Matticus ...
    23 Feb 2008
    Really well featured case, coolermaster have really hit a great price point with this one. The original 690 should have had some of these features, such as the ability to mount a 2x120 radiator. I just had to mod mine in.
    I will say though, I do think the original one looks a bit more aggressive. I think because the bottom of the front panel curves up on the new one whereas it went straight down the floor on the older model gives it a more sort of combine train look :p. Though that may be something to do with the fact the rails on mine are black for a stealthier look.
    I am slightly disappointed I have the original as I would like the new one, but can't bring myself to upgrade to what is called the same thing, even though its a far superior case.
    Oh and of course, very nice review.
  9. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Might get this, a Core i5-750 (and the necessary mobo), a GTX260 (dirt cheap now) and two WC loops just for the sake of it.
    Then again, I don't have money. Well, one can dream. :X
  10. memeroot
    memeroot aged and experianced
    31 Oct 2009
    quite a nice case but the plastic puts me off.
  11. Hustler
    Hustler Minimodder
    8 Aug 2005
    "or a sharp edge waiting to slash our fingers"
    Your telling me, i was left with a deep, 1 inch long cut, spread across 2 fingers last year when building my Coolermaster based PC....
    You try building a PC with 2 thick plasters on your fingers......it aint easy, i can tell ya....
  12. do_it_anyway
    do_it_anyway Minimodder
    24 Apr 2009
    1 inch deep? You don't need plasters for that, you need a plastic surgeon!
  13. Hustler
    Hustler Minimodder
    8 Aug 2005
    Yeah..lolz, edited for accuracy.....
  14. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    Great review, although I would've liked to see how the case performed without that lower 3.5" cage. As soon as I saw those 3.5" bays were across the case I was put off, but it's great that they've given the option to remove them. I reckon with the lower cage off the components would get much more air to them and the temperatures would drop a chunk.
  15. azrael-
    azrael- I'm special...
    18 May 2008
    There are several, tbh... :)
    Interesting case, but ever having owned a Lian-Li spoils you...
  16. crazyceo
    crazyceo What's a Dremel?
    24 Apr 2009
    Use a Corsair HD50 for the CPU cooler and move the quiet 120mm fan off the back and put it on the side above the gfx card/s. That should deal with a lot of the temp issues and still be quiet as a mouse running around on cottonwool eating candyfloss!
    I like it!
  17. crazyceo
    24 Apr 2009
    Sorry H50*
  18. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    * waits for a Fractal Design R2-esque backlash *...
  19. Omnituens
    Omnituens What's a Dremel?
    5 Apr 2006
    Still only has 7 PCI slots :/
    Was disappointed to find my 840 only had 7, meaning I cant use a dual-slot card in the bottom PCI-e :(
    If I had the tools to cut a slot, it could fit at the cost of the lower support brace.
  20. tonyd223
    tonyd223 king of nothing
    12 Nov 2009
    Hey - no backlash - it's a nice case that of course will perform better with more fans. Would have liked to have seen dust filters on the side panel as that's the obvious initial fan upgrade. Still think these cases (in light of terabyte HDD's) have too many HDD slots, and also too many ODD slots as well - would be nice to see a much smaller case - but that's just my current madness...
    Nice review, nice case - Coolermaster can do no case wrongs at mo
Tags: Add Tags
