News Cooler Master debuts ESA Cosmos
Discussion in 'Article Discussion' started by Da Dego, 13 Nov 2007.
  1. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
  2. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    I forget if the fans are power by USB as well as controlled by it. If so, that would be quite cool (sorry). It definitely beat running 3 fans of one motherboard header:worried:
    Nowhere seems to sell it though, do you know how much more it is that the usual one? $229 is cheaper than £140 in the original article, but that is in the US
  3. Risky
    Risky Modder
    10 Sep 2001
    Still the weakness of this is that is will relay on the OS, so in the event of a crash you lose all control. Now a software controllable system outside the primary system is what you really need e.g. something grown out of the t-balancer concept.
  4. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    the ideal would be a second, behind the scenes OS, like some flavor of linux, running on the background out of your way...... and i very much doubt the fans would be powered by USB.....
  5. Cupboard
    30 Jan 2007
    no reasons I can think of why not. If you can power a hard drive/light/fan/drinks cooler from one, why not a couple of case fans?
    I don't really know though (hence the question)
  6. completemadness
    completemadness What's a Dremel?
    11 May 2007
    A 80mm case fan is usually about 0.1A (in my experience) - maybe more depending on size/speed, However, that's at 12v
    Don't forget, USB is 100mA max (non negotiated) or 500mA (negotiated) but that's at 5v
  7. DXR_13KE
    14 Sep 2005
    exactly what i was thinking...
    maybe it is powered by the psu, but has a usb connection for speed control and noise control.
  8. completemadness
    11 May 2007
    I would be very surprised if it wasn't done that way :)
  9. Anakha
    Anakha Minimodder
    6 Sep 2002
    I think a board like that would operate so when there isn't a negotiated connection with some controlling software, the fans run at 100% (Or use an onboard thermistor, or have some other setting stored in a tiny CMOS chip so you can control how the system starts/runs). That would be the sensible way to do things.
  10. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    i think that bit needs to get one as a follow up to the esa article
  11. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    wait Im confused dont most motherboard already have the ability to control fans? or at least CPU/SYS/Chassis fans for one and then you can get USB Fan controllers already that can do the same thing so whats the point? If someone could explain a little more that would be great.
  12. HourBeforeDawn
    26 Oct 2006
    oh there was rumor that CM was going to release an all aluminum version of the cosmos around Dec/Jan, could that also be whats different with the ESA Cosmos? as that was the case I was holding out for. ^_^
Tags: Add Tags
