News Cooler Master's Cosmos is nearly ready
Discussion in 'Article Discussion' started by Tim S, 13 Jun 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Hiren
    Hiren mind control Moderator
    15 May 2002
    Wow, that's fudgy. For £120 there way nicer looking cases about.
  3. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    I'll await the bit review before thinking about buying.
    good to see they kept the HDD enclosure concept
  4. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    looks hideous tbh
  5. Krikkit
    21 Jan 2003
    First thoughts: hideous.
    Second thoughts: better.
    It's starting to grow on me tbh, alright it's not really plain, but it's enough imho, and the cooling looks awesome. I'll wait for the BiT review, then make a final judgement. :thumb:
  6. XeroNXS
    XeroNXS What's a Dremel?
    8 Feb 2007
    Looking quite good imho. :)
    But for 177€ I can probably buy a better looking aluminum case.
    What I don't get is why Cooler Master wasn't able to build a proper rig.
    It looks really messy inside.
  7. cool_dude
    cool_dude Minimodder
    26 Aug 2004
    Discusting.
    //Wishes ATCS would come back to them....:(...
  8. ./^\.Ace./^\.
    ./^\.Ace./^\. What's a Dremel?
    7 Jun 2007
    It needs some work. Maybe a hamer could fix it :D
  9. stevehp
    stevehp What's a Dremel?
    6 Jul 2002
    What bar? The images on this site are always too small and not expandable if you're going to point something out zoom in on the image or whatever to get your point across.
    I know what bar(duct) you are speaking of Antec had them in the older P180s horrible solution made way too much noise.
  10. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    put the fans closer and make it a little cheaper and you have a deal.... after i read the review..... :D
  11. Tim S
    Tim S OG
    8 Nov 2001
    My apologies - hectic first day back in the office... :blush:
    Check here: http://www.bit-tech.net/news/2007/03/15/cooler_master_shows_concept_case_design/1
    I'm referring to the bar that runs across from the rear I/O to the drive cage. I know a lot of manufacturers have used similar "bars" for "extra support" but this isn't about that load of rubbish, it's more of an air duct than a bar, I guess - I'm in bad habits from times of old :duh:
  12. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    Are the things that look like handles actually handles, or will they fall off if you try and lift the system with them?
  13. Tim S
    Tim S OG
    8 Nov 2001
    I believe that the current cases are handmade, so it's not recommended. But on the retail cases, these should be "handles", afaik.
  14. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Are those bars on the top and bottom fully functional handles, or are they just there for show?
  15. CollinstheClown
    CollinstheClown Hi
    30 Jul 2005
    Read about... one post up...
    -CollinstheClown
  16. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    Now that's just hiddeous.
    I like that they have moved the PSU to the bottom though,
    is there a vent under there so that there is cooler air for the PSU? All cases should place the PSU at the rear base of the case.
    It looks like cable routing will be the toughest part of making that case look good. I cant believe they chose to showcase that with such terrible cable management, if they had spent 3 minutes more on that, added watercooling it would really help make the rig look better.
    Shame that the plastic they have used makes it look so cheap. I know it's £120 but they could have pulled of something a little mory classy...it looks like something from the set of a very bad F Class Sci-Fi movie.
  17. wharrad
    wharrad Minimodder
    26 Jul 2003
    Ach Coolermaster went wrong when the guys that now form Silverstone left. ATCS cases were great with the understated design and all brushed ali. It just seems to me that now they use their good name to put high prices on lower quality steel/plastic cases.
    Silverstone or Lian-Li is the only way forward at the moment.
  18. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    The hard drives looks like there stack sideways at the bottom, which concerns me with regards to keeping them cool due to restricted air flow across them :eyebrow:
  19. Atomic
    Atomic Gerwaff
    6 May 2002
    Those were indeed nice cases.
  20. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    I see some kind of father ted moment.
Tags: Add Tags
