Scratch Build – Complete Cor Leonis
Discussion in 'Project Logs' started by Attila, 28 Feb 2011.
  1. Gentleman_Dingo
    Gentleman_Dingo What's a Dremel?
    30 Aug 2007
    eeehhh.... I'm hoping the curve works out for you. I'm going to be annealing some aluminum to make a curve on my case. I'll tell you how it worked out as it might be an option for post-cutting bending.
  2. Combatus
    16 Feb 2009
    No problem mate, our pleasure - glad to see it's been put to good use. As for the project...:jawdrop:
  3. bulldogjeff
    2 Mar 2010
    Looking soooooo good. that front panel almost looks alien like...nice work
  4. Cheapskate
    13 May 2007
    Rolling mill - Awesome!
    Can't roll cut sheet - Crud!
    Can cut after rolling - Yay again! -But d*mn, what a pain.
  5. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Interesting design and a new challenge for you. An English wheel is what you need, now if you can justify the cost, only your imagination would hold you back :lol:
  6. Shazbom
    Shazbom What's a Dremel?
    18 Jan 2009
    nice work and silks man. i wish i have all that aluminum. its expansive here in uk. =(
  7. HighWire
    HighWire What's a Dremel?
    21 Mar 2005
    I'm eh... Well... What I'm trying to say is...
    Gah, lost for words... Simply amazing!
    I'll run along now and clean up this puddle of drool I seem to have left behind...
  8. talladega
    talladega I'm Squidward
    18 Aug 2007
    i love this! i somehow missed that you started this build so i went through it all. cant wait to see more progress. :thumb:
  9. voigts
    voigts What's a Dremel?
    26 Apr 2006
    This is looking better and better. I'll be watching...
  10. Attila
    Attila still thinking....
    22 Feb 2008
    Thanks, no, it's a loooooong way from finished. :hehe:
    I did read the WMD worklog but that was a long time ago and I forgot the details. If I had remembered, it could have saved some time and metal. :thumb:
    Yeah, not having much luck finding a place to do it. :rolleyes:
    Haha, thanks. :hehe:
    Thanks. :thumb: Don't worry, I check every update you make. ;)
    It's been many years since I've used and AMD powered system, and that case is lovely. :)
    Thanks mate. :thumb:
    Thanks cheaps. :thumb: Things like this waste an awful lot of time, mainly because I drop my view of the big picture and get bogged down with details. :rolleyes:
    Thanks, an english wheel is useful to make compound curves but I only need to put one curve into the back door. The final design will be different from the pics. :)
    Thank you. :thumb: It's not cheap here either.
    Haha, thank you. :hehe:
    Thanks and Welcome aboard. :)
  11. Cleveland216
    Cleveland216 Carbon Fiber King
    30 Dec 2007
    You know what would be great, is when you update your log, that you post in your title that you have updated!
  12. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Nice job on the very neat vents Attila :thumb:
  13. sethnmalice
    sethnmalice What's a Dremel?
    21 Jul 2007
    you could make a wooden vice with the intended curve, then clamp and press the 3 pieces together, it would eventually mold to the curve.
    The warping of the alu is because the piece is too small to go through the roller, you could use a much larger piece, roll it, then cut the excess off.
    Coming along nicely.
    How are your hands and fingers holding up ? i had to stop modding because the manual labor was becoming too much.
  14. Waynio
    Waynio Relaxing
    20 Aug 2009
    ^ Thats a good idea but you'd need to make the mold an exagerated version of what curve you want or there will be some flex but to be honest that probably wouldn't matter once it's fixed to the case & with the little extra force the panel will have should add a little more strength, the alu curve bars I did on mine added a load of extra strength so didn't need to put extra supports in :).
  15. Cheapskate
    13 May 2007
    You can also take the sheet out to a sandy spot in the yard, and drop a bowling ball on it.:D -also a good way to ruin a bowling ball.
    @Sethn- I told you to stop when you see blood!:nono:
  16. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Try a panelbeater's bag and mallets. Grew up swinging them in my father's shop-which is why i use wood so much, hee hee.
  17. Attila
    22 Feb 2008
    Thanks for the replies but the only way for me to get a nice even curve is to roll it. I've wasted a couple of weeks on this already so I'll move onto something else and come back to it later.
    @sethnmalice Wow, that's pretty bad news. I have no problem with my hands. Even though a part may take ten hours to file, it never gets done in one session. Most times I'm building, I can only get an hour or two in because I don't have the extra time. If you have been using that nibbler all day then no wonder you have problems. I think if you can heal up and get better, then you can get back into it but in a very controlled way. Oh, and throw the nibbler away, it's a killer.
  18. KayinBlack
    2 Jul 2004
    I did, and I'll never look back.
  19. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    I don't know.... seems pretty useful to me?
  20. dec0y
    dec0y What's a Dremel?
    21 Feb 2011
    Great work, I can't imagine how hard it was to do all this.
    One thing that bothers me is that the fans might not get enough air with the small chevron cut outs, but that's just me.
