Reviews Corsair Hydro X Liquid-Cooling Kit Review
Discussion in 'Article Discussion' started by bit-tech, 24 Feb 2020.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Vault-Tec
    30 Aug 2015
    404 cool :D
  3. maverik-sg1
    maverik-sg1 Minimodder
    18 Aug 2010
    Air bubble in the CPU block would do my nut in, I can't help but feel that tilting the case would of got rid of that and maybe had a positive effect on the cooling?
  4. Anfield
    Anfield Multimodder
    15 Jan 2010
    Unless you go to ridiculous extremes you can ignore the entire debate around the amount and application method of thermal paste.
    Just make absolutely sure you never show or tell anyone how you do it.
    (Because people are immune to test results that prove the debate is BS and attack you regardless).
    The_Crapman likes this.
  5. jb0
    jb0 Minimodder
    8 Apr 2012
    I'm pretty sure that particular air bubble will have only aesthetic effects. The CPU block Corsair designed has a lot of extra space in it, and Mister Bubble is nowhere near the heat transfer fins. So that bubble's got a pretty small surface area to work with, and it isn't directly over the die. (I think the area the bubble is in only even exists for aesthetic purposes, making the bubble's refusal to leave it actually kinda funny)
    But yeah, laying the case on its side for a couple seconds would get that air out and flood the entire chamber like nobody's business. Surprisingly, it actually purged itself the first time the loop was filled, before they added the video block. It may decide to leave with a power cycle.
    maverik-sg1 likes this.
  6. Zak33
    Zak33 Staff Lover of bit-tech Administrator
    12 Jun 2017
    this... /\ with huge bells, and golden chimes and all sorts of lighting, and singing angels.
    Few people agree... and fewer still with my way ;) @MLyons
  7. The_Crapman
    5 Dec 2011
    The air bubble didn't appear to be their when it was just the CPU block, so wouldn't have had any affect on the results. But yeh that would do my head in too. Spent half an hour chasing bubbles out a GPU block the other week. Little ******* kept popping back in every time I thought I'd clear him.
Tags: Add Tags
