Hardware Corsair Raptor K40 Review
Discussion in 'Article Discussion' started by Meanmotion, 24 Mar 2014.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. Teelzebub
    27 Nov 2009
    Sure is ugly :eek:
  3. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    Beauty is in the eye of the beholder, I think it looks quite smart.
    I may be wrong and have missed it, but I didn't see mention of a gaming switch to turn off the windows key.
  4. Baz
    Baz I work for Corsair
    13 Jan 2005
    It's the little padlock key next to the array of macro keys at the top. When lit, windows key is disabled.
  5. RichCreedy
    24 Apr 2009
    ok, good
  6. David
    7 Apr 2009
    I understand the need to reduce costs, and the argument for the high cost of mech boards was the additional cost of the MX switches. Having a membrane and rubber domes should bring the cost sufficiently; without resorting to trying to make plastic look like aluminium.
    Over-priced and tacky-looking.
  7. Hustler
    Hustler Minimodder
    8 Aug 2005
    I think if I spent this much on a non mechanical keyboard, after the novelty has worn off in a couple of days looking at the fancy backlighting, I'd be kicking myself for not saving up a bit longer and spending that little bit extra for the real deal TBH.
  8. Teelzebub
    27 Nov 2009
    Sure is :eeek:
  9. The_Crapman
    5 Dec 2011
    I don't see why this guy should have the final say
  10. Guest-44432
    Guest-44432 Guest
    These Mechanical keyboards are slowly getting my interest up. Just needs a USB 3.0 socket at the back for when I want to use a USB flash stick or for quick setup/dismantle of my G25. Then I will buy one! ;)
  11. David
    7 Apr 2009
    Be careful, mate. This one isn't actually a mech board, it's just been tarted up to look like their mech boards.
    However, I wouldn't limit the range of selection of boards based on USB 3.0. You'd be better off with a hub mounted in the front panel or an external one on the desktop, then take your pick of some of the lovely boards on offer. :)
  12. Guest-44432
    Guest-44432 Guest
    Oh right. I guess I haven't been interested in Mech boards before, that I never bothered to do my research into them.
    I can't use front panel as it gets messy, and a desktop hub is not what I want either, as it will add more clutter to my desk.
    When I had my G19 keyboard (Wish I never sold it!) the 2 USB ports was perfect.
    I'll wait till they bring one out, but backlit keys is a step in the right direction, especially when your playing with the lights off! :)
  13. Anfield
    Anfield Multimodder
    15 Jan 2010
    The backlighting is brilliant especially if you live somewhere near water.
    What on earth does one have to do with the other?
    Living near water = unholy number of insects in summer = can't have window open after dark as having the lights on would attract all the critters, a keyboard backlight however is bright enough to see what you type while at the same time not being bright enough to attract insects.
Tags: Add Tags
