Hardware Crucial MX300 and MX300 M.2 Reviews (525GB & 1TB)
Discussion in 'Article Discussion' started by Dogbert666, 13 Jan 2017.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. Xir
    Xir Modder
    26 Apr 2006
    Missing the de-facto-standart 850 Evo for comparison here a bit.
    Was this with the newer M0CR040 firmware?
  3. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Wonder how long it will be before the prices of SATA M.2 drives and NVME ones coalesce?
    It's starting to feel a little like the previous SSD v HDD switch haha. Can grab an NVME drive for OS speed and then a cheaper SATA SSD for storage.
  4. Anfield
    Anfield Multimodder
    15 Jan 2010
  5. Hustler
    Hustler Minimodder
    8 Aug 2005
    The 1Tb drive would make a perfect (relatively) cheap drive for a large Steam library.
    Some games like GTA V really do benefit from the faster streaming speeds of SSD's as they build the open world around you in game.
    .yes, very tempted to shift over my Steam games to one of these.
  6. SinxarKnights
    SinxarKnights Minimodder
    21 Jan 2007
    :worried:
  7. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Just done exactly this with a 960GB Sandisk SSD I got on Amazon Deals late last year. :thumb:
  8. Wwhat
    Wwhat Minimodder
    2 Oct 2005
    Strikes me as very odd to have M.2 modules that transfer no faster than SATA. What's the point then?
  9. RedFlames
    23 Apr 2009
    It's the same speed as the SATA version because it is SATA drive. And the point is mainly for laptops and boards that use/support M.2 SSDs but that don't support the PCI [be it AHCI or NVMe] versions.
  10. Guest-16
    Guest-16 Guest
    Only Haswell-era ones. Anything Skylake and Kaby will have PCIE based M.2.
  11. derekthetree
    derekthetree What's a Dremel?
    25 Jul 2012
    I got the 525gb SATA drive for £80 near black Friday. Finally got round to installing it (clone wasn't straightforward...) but impressed so far. My first ssd!
  12. Wwhat
    Wwhat Minimodder
    2 Oct 2005
    But are there many laptops/boards that have M.2 but only at SATA speeds? Because I would think that once you put in M.2 you would make sure it can do more than SATA.
    But either way, thanks for giving an explanation.
  13. RedFlames
    23 Apr 2009
    Enough to warrant them bothering... Mainly in the thin and light/ultrabook segment [and the Macbook Air/some version of the MBP iirc] where space constraints meant there wasn't enough space for a 2.5" SSD...
Tags: Add Tags
