DDC Pump
Discussion in 'Watercooling' started by b1g-d0g, 21 Sep 2018.
  1. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    I'm looking at getting the DDC pump with the EK upgrade kit for a phantek res for my build,my main worry is will this pump be reliable as the last time I had one was over 5 years ago and I've read about there being a high failure rate with these.
  2. alfizzle
    alfizzle Ooh aah just a little bit..
    3 Apr 2013
    IMO If you fit a heatsink to the ddc it’s as reliable as a d5.
    I’ve been running a ddc at full speed nearly 24/7 with an ek heatsink for over a very long time and it has been absolutely fine.
  3. Big Elf
    23 Apr 2009
    I'd get one with PWM so you can set it to lower speeds when not under load.
    My PWM Swiftech DDCs are 7 years old and still running fine with the speeds set to around 1800rpm for the vast majority of the time. It also helps cut down noise levels as well. I don't think the non-PWM DDCs fail that often though but they do benefit from cooling as they run hot compared to a D5.
  4. The_Crapman
    5 Dec 2011
    I've had no problems with my 2 in the 4 years I've been running them.
  5. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    That's great new thanks for that,what will aid to the cooling as well is the res will be mounted on the front 140mm intake fans and as this res is slim there should be a fair bit of cold air going over the ddc.
  6. iggy
    iggy Minimodder
    24 Jun 2002
    ive had the same pump running for over 7 years now.
  7. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    Holy cap that's amazing mate :)
  8. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    I've found this ddc alpha cool laing ddc-pump 12vddc-1t pwm comes with no top and has the cooling upgrade installed,would be great as I plan to get the phantek r220 rez.
  9. cobalt6700
    cobalt6700 Minimodder
    17 Oct 2005
    Got my non-PWM DDC second hand (>1 yr old) and had just over 9 years of use in my main rig before being retired. Still works just fine.
    Just had an Alphacool top fitted to it - no heatsink (It should of had one but I never got round to )
