Graphics decisions 560 vs 570
Discussion in 'Hardware' started by blinkieleblind, 17 Mar 2011.
  1. blinkieleblind
    blinkieleblind Tings and such
    22 Feb 2010
    Ok so i bought a new monitor and my HD 5770 isnt quite cutting the mustard any more. I was going to buy the MSI gtx 560 from scan hoping it would be on the 'today only' deal today but it wasn't.
    They do have however a MSI gtx 570 card on offer for ~£245 which is a bargain.
    the question is whether to fish out an extra £35 on the 570 with the stock pcb but still have some overclocking headroom or go for the 560 which can match the 570 at stock and has an awesome cooler?
  2. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    I'd go 570 everytime. While at the moment the high clockspeeds make the 560 performance look good in the benchies a few years down the line when the going gets tough that same 560 is going to start running into a lot more architectural roadblocks than it's bigger brother. Having less ram, a narrower memory bus, less stream processors and ROPs etc all add up reguardless of the clockspeeds. You know what they say, A system is only as strong as it's weakest part.
  3. Guest-56605
    Guest-56605 Guest
    Or you always have the SLI 560 option, buy one now and another at a later date... :)
  4. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    +1 for 570, £245 is a bargin for a 570 even if it is standard cooler and standard pcb, means in future you can either buy an after market cooler or stick a water block on it, and overclock the bee jeeeessuss out of it with msi's afterburner software :D also although the 560 could match a 570 with a good overclock you've got to think that you can also overclock a 570 to, not to as crazy levels obviously but still good enough to bring it in line with a stock 580
  5. markbrett64
    markbrett64 thanks to denial I am now immortal
    12 Jan 2010
    Whenever I've gone for the 'sensible' option I've regretted... so I say get the best you can afford.
    GTX580 anyone?
  6. blinkieleblind
    22 Feb 2010
    thanks guys, just what i wanted to hear. Other people's voices convincing me to spend more money..... This way when the girlfriend gets pissed with me i can say that the voices made me do it! :D
  7. Madness_3d
    26 Apr 2009
    Hehehehehehehehehee
  8. Marine-RX179
    Marine-RX179 What's a Dremel?
    24 May 2010
    What about Gigabyte GTX480 SE for £224.99 plus 10% off? That would be just over £200 and that would make it around £40 cheaper than the GTX570:
    http://forums.overclockers.co.uk/showthread.php?t=18253177
    Yes it has higher power consumption than a GTX570, but it is slightly faster than it due to the higher frame buffer, and with the 3 fans Windforce custom cooler it's actually cooler and quieter running than a standard GTX570.
  9. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Great call but remember it only works once, maybe twice, if you are lucky. You'll have to think of another excuse for your next purchase.
    Now, maybe a Sandy Bridge upgrade for the rest of your rig...
    :D:D:D
  10. Guest-56605
    Guest-56605 Guest
    After that sleep with one eye open and hide your credit cards :hehe:
