Displays Difference Between These 2 Monitors
Discussion in 'Hardware' started by slim, 6 Jan 2012.
  1. slim
    slim What's a Dremel?
    16 Oct 2011
    I orderd LG LPS236v-pn and recieved lps235v-bn is there any difference between those 2 in terms of quality? they seem the same on stats wise but :p
  2. GoodBytes
    20 Jan 2007
    Montreal, Canada
    I think you mean:
    LG IPS236V vs LG IPS235V
    LG IPS235V is a newer revision, form what I can tell. And LG specs says that it's 8ms response time instead of 5ms. (But they might be the same, just LG changed which 2 colors they choose for the gray-to gray measurement).
    And the LG IPS235V (based on LG sites, unless it's a typo) there is no wall mount VESA mount support.
  3. slim
    16 Oct 2011
    LG IPS236V-PN 23 http://www.amazon.co.uk/gp/product/B000BSYVWY that's the one i bought but if your saying that the one i bought is 8ms rather than the 5ms that is advertised it seems like i've been conned.
    the lg web site says ips235v which is the one i received is 14ms
  4. BennieboyUK
    BennieboyUK CPC Folder of the Month Sep 2011
    24 Nov 2010
    Personally I always like to get what I ordered, if nothing else makes making warranty and return claims that much easier.
    I'd be contacting Amazon.
  5. slim
    16 Oct 2011
    i've contacted the sub comapny but it was bought at amazon
  6. GoodBytes
    20 Jan 2007
    Montreal, Canada
    I agree. The only time I accept a different product, is when the product I have is much better, to compensate for the trouble I'll have come to warranty, if needed.
  7. slim
    16 Oct 2011
  8. slim
    16 Oct 2011
    This is what LG said
    Dear Mr Smith,
    Thank you for your email.
    The two different product codes at the end of the model number refer to minor revisions of the componenets within the unit itself. It may be that at the time of original manufacture, the PN model used one component whereas the revised BN model uses an alternative one. The codes are more for manufactural use and do not bear any relevance to the customer.
    I hope this has been of use. Should you require any further advice or assistance, please do not hesitate to contact us again.
    Thank you for choosing LG Electronics.
  9. GoodBytes
    20 Jan 2007
    Montreal, Canada
    I think LG miss understood you.
    It's not the "BN" "PN" it is the difference between ips235v and ips236v
  10. slim
    16 Oct 2011
    It's mega confusing all this and it's a pain in the Bottom. I just wish i was given what i bought the ips236v the one with the brown tint to the stand.
    To me there saying that it's the same and stats wise it appears that way but i like the look of the ips236v and i don't know if the Response time of the one they sent me is the same it's all a bit of a f up
    and Thanks for you help dude
