Do I go Ryzen 3700 or Intel
Discussion in 'Hardware' started by numanoid, 20 Sep 2019.
  1. numanoid
    numanoid Modder
    26 Apr 2009
    Hi guys
    I'm getting the final pieces (motherboard cpu and memory) to my gaming rig, do I go ryzen 3600 or get an i7 8700k based system, I have a gtx 1070.. thanks
  2. sandys
    sandys Multimodder
    26 Mar 2006
    8700 is the better gaming chip.
  3. numanoid
    numanoid Modder
    26 Apr 2009
    Thanks buddy
  4. numanoid
    numanoid Modder
    26 Apr 2009
    Cheers buddy, saves all the hassle of updating the bios for the ryzen chip..thanks
  5. SuperHans123
    SuperHans123 Multimodder
    27 Dec 2013
    £170 difference for 4fps.
    I know what I'd get. (and did)
  6. Tech Cave
    Tech Cave What's a Dremel?
    18 Sep 2019
    go ryzen, newer chip, lower price and almost same gaming performance with better multithread
  7. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Nice necrobump.
    goldstar0011 likes this.
  8. Parge
    16 Jul 2010
    I'd be going Ryzen just to support AMD, personally.
  9. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    This is the age of Ryzen, no good reasoning for shintel at the moment.
  10. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    Get a Ryzen CPU and motherboard and save the money for a more beefier GPU is what I'd suggest
  11. Gian
    Gian What's a Dremel?
    14 Nov 2019
    In resolution 4k is =
  12. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    I think he's saying, albeit cryptically, that if you are gaming at 4K then you'll be GPU-limited rather than CPU-limited, so you'll get identical gaming performance between Ryzen and Intel's equivalent.
    I could be wrong, mind :D
  13. Parge
    16 Jul 2010
    Moved to hardware
  14. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    The only reason I will is I hate ZIF sockets and want the mto be put in the bin of history! Otherwise I totally would go AMD!
  15. Vault-Tec
    30 Aug 2015
    It's actually possible to quite easily repair a snapped CPU pin yet nigh on impossible to repair a CPU socket pin.
    I literally got sweaty when I opened up my X399 socket.
  16. Bloody_Pete
    11 Aug 2008
    But its also far far harder to damage a socket, motherboards tend to cost less and LGA sockets have glfar better cooler retention systems usually!
  17. Otis1337
    28 Nov 2007
    Not using a CPU that will last years and use the socket for about 10 seconds in 5+ years is a little silly.
    But you do you man lol.
  18. Vault-Tec
    30 Aug 2015
    I've damaged two sockets beyond repair. One pin. I've never damaged a CPU with pins ever. The very fact that sockets now come sealed with a cover says it all. IE - manus got sick of taking boards back with bent pins. There are numerous warnings about it in the manual.
    You also need to make sure that every screw is torqued evenly, or pins can refuse to make contact etc. This is particularly an issue with Threadripper.
    Any way, our issues with sockets and pins on CPUs aside I agree with Otis. It's something you have to do once, maybe two times in years. As long as you do your research before hand it's almost impossible to mess up unless you drop something which is human error. It's a silly reason not to go Ryzen, basically, but as he says each to their own.
  19. Bloody_Pete
    11 Aug 2008
    Its choosing with my wallet. I don't like their design choice, I don't buy their product, simple as :)
