It's an Asus TUF GTX 1650 Super which isn't very long but does seem heavy on the PCI slot. The mobo is an Asus TUF Pro Wifi all in a Phanteks P600 case.
I've never used any sort of GPU support myself, cards are pretty much designed to distribute weight so it's not an issue. That said, if you don't like the look of sag or it concerns you I wouldn't put off getting a bracket.
Maybe, if you move your rig around a lot, like take it to LAN parties etc.. it might be a consideration. Otherwise, it really isn't necessary for a card that small. There's no downside in getting a support, though. So, if it eases your mind, go for it.
Thanks all for your feedback folks, I did buy one of these but it's too long and hits the fan (as you can see from my earlier pic), which does suggest that the GPU isn't long enough to need extra support.
I think you'll be fine, back in the day my 4870x2 weighed about a kilo and the motherboard survived fine (the pc wasn't moved about though).
That card is small enough that it's really not necessary. If you really want one, just find something solid that's the right size and stick in under between the card and PSU shroud. PCI covers work pretty well Tweet— Twitter API (@user) date
