Blogs Do modern EFIs make physical fan controllers pointless?
Discussion in 'Article Discussion' started by bit-tech, 3 Sep 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. DbD
    DbD Minimodder
    13 Dec 2007
    But you can just use a splitter and have one board slot control multiple fans - it's not like you need each individual fan going a different speed. That's what I've been doing since my core 2 duo (asus something deluxe mb). One for the cpu which controls the heatsink fan(s). Two for the case fans. Then I just link them to whatever monitored temp I like (cpu/northbridge/even gpu) and they all automatically ramp up and down. Much better then anything external where you have to manually turn dials or insert temperature probes or whatever.
  3. sandys
    sandys Multimodder
    26 Mar 2006
    "Do modern EFIs make physical fan controllers pointless?"
    Not yet, I use an aquaero to control my fans and can adjust all based on readings through software monitors that don't exist in EFI BIOS like DRAM and SSD temps where I wouldn't want to be routing probes etc as it's all register on chip, so why would I want to.
    Modern boards are good though, much better than they used to be, I am probably a fringe case to be fair, I could get away with using mobo in a pinch, my motherboard even has pretty good pump control.
  4. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    One of the most underrated features of Asus Strix cards (might be on other models, I just know it from personal use) is the inclusion of a fan header that can directly control fan speed based on GPU load - if your case has an intake mounted directly under or in front of the GPU, it's a no-brainer to use that and free up one of the motherboard headers.
    Omnislip and wyx087 like this.
  5. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Personally, for general usage, no we don't need them anymore. Most folks only have a handful of fans that can be easily served by even lower end motherboards.
    For niche use I'd say yes, but only if fan hubs are also lumped in with controllers. I've had an Aquaero 6 stuck on the shelf for what 4 years now and to date still never been tempted to use it, which I feel speaks volumes about how things have changed. Full motherboard control has so many issues with large numbers of fans though I've found, hubs at least still feel essential to me if you're using more than 6 fans, which is surprisingly common nowadays thanks to watercooling becoming so popular.
  6. Anfield
    Anfield Multimodder
    15 Jan 2010
    I use these for powering / controlling the fans on the rads:
    https://www.scan.co.uk/products/aka...-splitter-cable-with-sata-power-black-braided
  7. jb0
    jb0 Minimodder
    8 Apr 2012
    I'd say we never "needed" fan controllers. Most of the ones I saw in the day were definitely in the "nerd bling" category, and most of what WASN'T there just for looks was wildly over-engineered.
    I'd also say the popularity of case doors kinda put the kibosh on fan controllers worth having, since any protruding switches or knobs in your drive bay blocked the door.
  8. Maki role
    9 Jan 2012
  9. David
    7 Apr 2009
    My last fan controller went when I stopped building mutil-radiator loops, which was when I moved from Nehalem ~ 7 years ago?
    Since then, onboard control has been sufficient.
  10. RedFlames
    23 Apr 2009
    The death of external drive bays also killed that type of fan controller.
  11. gosh
    gosh Minimodder
    20 Oct 2009
    blast from the past, always had to have a couple of knobs mounted in a spare drive bay (or in a later case on the side of case itself) to turn down main fans when watching something on my old old pcs but not even thought about these in years. guess that answers that rhetorical question - i doubt it's the demise of physical bays in cases so much as the built-in motherboard controllers doing all the monitoring and automatically adjusting. Used to be a right faff with sticky temperature probes on those expensive led screen fan controllers and running wires back and forth, don't miss them one bit.
  12. Arthur
    Arthur It's for 'erberts !
    24 Nov 2009
    I got 2 x 6 channel fan controllers in my case. All 12 fans are individually controlled. Love tweaking those fan speeds :happy:
    The_Crapman likes this.
  13. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    I agree with the general consensus. Most of the time not required. But there will always be a MOD that will need the extra control options or needs it just for the cool factor. ...er seriously not a planned pun.
  14. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Had fan controllers on several cases, wired them up fiddled a bit then never touched them again, I personally wouldn't bother these days.
    Osgeld likes this.
  15. jb0
    jb0 Minimodder
    8 Apr 2012
    The dearth of external drive bays certainly put the final nails in the coffin(I miss cases with a half-dozen punch-outs on the front), but ... I'd argue that they were basically dead before that happened.
  16. wyx087
    wyx087 Multimodder
    15 Aug 2007
    This is the case for me. (ha)
    I've still got the same case I bought ~8 years ago. I have an automatic fan controller programmed up, it's hidden inside a HDD bay, it uses temperature probes for auto fan control and its profile is saved onboard. I have changed motherboard and reinstalled Windows, never had to touch the fan controller, it just works.
    Without any plan to change my case, I hope I'll continue to not worry about cooling for the foreseeable future.
  17. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Chassis fans? What are those? [/SFF]
  18. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    Sounds interesting...what is this piece of wizardry?
  19. wyx087
    wyx087 Multimodder
    15 Aug 2007
    Check out my write up here: https://forums.bit-tech.net/index.p...automatic-fan-controller-bigng-review.227452/
    (2012, wow, time really flies)
    Only thing I haven't changed over the years is the controller, HDD and case. But I haven't re-configurered it all those years. Now I do a bit of cryptomining using solar power, the original setting still works well.
  20. ModSquid
    16 Apr 2011
    What's with the Phtobucket stuff (new to me on here)? Safe to open?
    Intrigued!
Tags: Add Tags
