Scratch Build – In Progress DONT LAUGH TO HARD... my res'
Discussion in 'Project Logs' started by DonT-FeaR, 15 Jun 2009.
  1. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    well..
    got bored on the weekend and made some res' idk if they would work but meh...
    look cool...ish..
    (they are water tight)
    this one is pvc and is nearly done.. needs some things to stop it from breaking under pressure.
    this one /\ holds 750mL... may be going to a socks for his donation project...
    if not.. will sit in house.. for sale if u really want it .. lol..
    res 2
    aluminium and holds 1.5L needs a few poprivits.
    well thats it for now.. just needs some poprivits and barbs and its done....
    not to bad for a first try... i think...
    seen as it was a spirit of the moment thing
    thanks for looking lol.. :)
  2. Voluntary_Pariah
    Voluntary_Pariah a Real Man™
    23 Jan 2009
    Nice work. Especially on the second one.
    The only way I can think of improving it would be to add a window, but that is my opinion.
    Seriously, good work
  3. sock58
    sock58 Budget mods
    6 Jun 2008
    Im loving these 2 res's. especially as they are your first attempt. Id love to have the top one. Have a look at how much postage is to the UK.
    I dont think ill use it as a res though quite yet, think i might use it as a feature and then do something with it later. As we talked about briefly on msn yesterday.
    Loving this though, i think a window in either of the res's would be amazing......
  4. DonT-FeaR
    23 Jul 2008
    thanks mate..
    yeah was thinking bout a window..
    but the second one has better things planed :)
  5. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
  6. The boy 4rm oz
    10 Apr 2008
    Love the alu one, shame it is alu though. God dammed corrosion lol.
    If you make any more perhaps think about making them smaller, 30cm is very large for a res and wouldn't fit in most conventional cases, you could feed 3 loops off the alu one. OMG @ 1.5L lol.
  7. Cheapskate
    13 May 2007
    You have to love PVC. It's dirt cheap an plentiful. That could use a little sanding, though.
    It's been a long time since I've seen heavy use of PVC on a casemod...
  8. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    They don't look bad for your first res
    I like the aluminum one, maybe you should fill in and smooth out the caps
  9. DonT-FeaR
    23 Jul 2008
    ah jase..
    thats a 15cm ruler.... :)
    thanks guys.. they arnt done but....
    idk what im gunna do to em..
    just got bored lol
  10. The boy 4rm oz
    10 Apr 2008
    Ah true lol, well I did post it at 2am lol. Still that thing is huge lol. My entire loop with duel rads, CPU block, GPU block, pump and res holds around about 1.3-1.4L.
  11. MIGUI
    MIGUI What's a Dremel?
    27 Feb 2009
    Nice work DonT-FeaR :thumb:
  12. serial_
    serial_ What's a Dremel?
    11 Oct 2005
    DonT-FeaR,
    Since you plucked your head into my log, I thought i'd do the same for you. And I must say that your 2nd res is absolutely smashing! Very well done. Gives me a cool idea for an all-aluminim case, where everything that can be is brushed aluminum.
  13. barry99705
    20 Apr 2008
    Hey, is that first one using cast acrylic for the ends?
  14. DonT-FeaR
    23 Jul 2008
