Notebooks Drivers needed
Discussion in 'Tech Support' started by numanoid, 20 Sep 2009.
  1. numanoid
    numanoid Modder
    26 Apr 2009
    hi all
    im doing a laptop for someone, dell vostro 1000 and need these 2 drivers for xp pro 32 bit
    these are the drivers i need
    the base system devices hardware id is
    pci\ven_1180&dev_0843&subsys_022a1028&rev12
    pci\ven_1180&dev_0843&cc_088000
    the sm bus controller id is
    pci\ven_1002&dev_4385&subsys_022a1028&rev_14
    pci\ven_1002&dev_4385&cc_0c0500
    thanks guys
    take care all
  2. Krikkit
    21 Jan 2003
    Have you downloaded all the relevant drivers for the thing from the Dell website? They have an extensive catalogue of the different drivers needed, and you can access them by service tag for specific-only goodness. :thumb:
  3. numanoid
    numanoid Modder
    26 Apr 2009
    hi m8
    ive tried that, got all the drivers but ive still got these 2 highlited yellow in device manager under other devices
    cheers m8
    take care
  4. Krikkit
    21 Jan 2003
    Have you checked for add-in cards or something? That sounds a bit weird. Nothing plugged in is there?
  5. Thermal5
    Thermal5 R.I.P
    3 May 2009
    Try here http://www.notebook-driver.com/dell/dell-vostro-1000-notebook-windows-xp-drivers-and-utility/ and look down the list for this specific driver "Chip Set: ATI SMBus / Chipset Driver, v.5.10.1000.7, A00 (4 MB) Vostro 1000 dated 13/09/2006"
    Then when you install the chipset driver I'm almost certain that the smbus part that's highlighted will disappear and possibly the second highlighted one as well, the smbus one always disappears when I've ever installed the specific chipset driver for any system I've ever used, let us know if that helps :thumb:
    EDIT: Looks as though that site might be down, therefore I checked on Dell.com and it comes up with several drivers for the Vostro 1000 see here Official Dell Website to download Drivers for the Vostro 1000 Notebook TESTED and WORKING
    Or try here http://www.driverguide.com you do need to sign up but it's free, and when I signed in and typed Vostro 1000 it came up with several drivers for it on there all for free download.
    thehippoz likes this.
  6. glendronach
    glendronach Minimodder
    1 May 2009
  7. numanoid
    numanoid Modder
    26 Apr 2009
    chees matey
    all sorted now thanks
    take care
  8. Thermal5
    Thermal5 R.I.P
    3 May 2009
    Your welcome, I take it you saw the links I posted for the drivers you required on the Dell website (which by rights should have been your first port of call ;)) anyway all the drivers you need for the laptop are there :)
  9. numanoid
    numanoid Modder
    26 Apr 2009
    hi matey
    well i downloade all the drivers off the dell website, but the 2 mentioned were not there
    thanks again
    les
