Displays Dual to single Monitor Macro key
Discussion in 'Tech Support' started by Stonerd, 14 Sep 2011.
  1. Stonerd
    Stonerd The monkey's out of the bottle, man
    1 Mar 2009
    Hey everyone,
    this is how my display setup is atm.
    23" dell ips monitor (dvi) <= pc => (mini hdmi) manual HDMI Switch <= PS3
    and
    manual HDMI Switch => 23" HDTV
    I probably made that more complicated than it needs to be. Anyway, I'm wondering if there's a macro key I can create so that when I hit the hdmi manual switch to go from my pc to my ps3 on the tv, I can also hit macro key on my keyboard and switch it from dual monitor to single (and vice versa). Is this type of macro key possible?
    Any information you guys could provide would be appreciated (even if that information is "you're an idiot". :p )
    Thanks,
    Stonerd
  2. Lance
    Lance Ender of discussions.
    6 May 2010
    Bump. I tried to work this out a few years ago and couldn't manage it. I would be interested to see if there is a way of doing it.
  3. adam_bagpuss
    24 Apr 2009
    i doubt you cuould do it as your crossing acorss several different pltaforms.
    the only way i could see it working is if the keyboard was plugged into an HDMI switch that enabled a double tap insert to switch or whatever. It would then just have to be recognised by the PC maybe via an usb lead from the HDMI switch to PC.
    I think that would work although not sure i it exists. If not you saw it here first and its MINE
  4. Stonerd
    1 Mar 2009
    sorry i know how illegible my first post was, i dont want the key on the switch, i can manage hitting 2 buttons, the switch and my keyboard. lol
    all im looking for is a way to create a macro key on my keyboard that will change my monitor setup between 1 and 2 monitors when i want to without having to go into display settings everytime i want to play my ps3.
  5. adam_bagpuss
    24 Apr 2009
    ohhhhhhhh
    have a look at ultramon you can set hotkeys in that. should work no problem
    Stonerd likes this.
  6. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Another very easy way if you don't want to install ultramon is create 2 profiles in your gpu control panel, one with 1 monitor and one with 2, then create a desktop shortcut and assign a winkey + character to them.
    Edit: forgot this isn't built into nvidia control panel, so if you have nvidia you would still have to install an extra program like nview or nhancer to be able to make profile shortcuts.
  7. Stonerd
    1 Mar 2009
    ultramon seems to be my answer, thanks a lot
    I do have a nvidia card but i can easily handle running another program, thanks anyway.
  8. GoodBytes
    20 Jan 2007
    Maybe I am not understanding correctly, so sorry in advance.
    But how about Win+P key
