Displays DVI to D-Sub cables
Discussion in 'Hardware' started by louist44, 23 Mar 2011.
  1. louist44
    louist44 Minimodder
    19 Jan 2011
    hi guys need help quickly please as Im trying to place my order on SCAN but I dont understand all this monitor stuff.
    The GPU I have is MSI GTX 560 Twin frozer, it has a mini HDMI and two DVI-I ports.
    The monitor I want has one D-sub port only, Could someone please find me a cable to connect these two together? Unless they come with the cables and I am being a complete idiot..:worried:
  2. sb1991
    sb1991 What's a Dremel?
    31 May 2010
    Most graphics cards will come with a DVI-D-Sub adaptor, but if not you can buy one, or a cable that does the same job (eg. this). If you haven't already got the monitor, I would try and find one that accepts a DVI connection, as it does give a better picture and doesn't have the flickering problems that an analogue connection can cause.
    louist44 likes this.
  3. louist44
    louist44 Minimodder
    19 Jan 2011
    Thank you very much!
  4. Parge
    16 Jul 2010
    What monitor are you buying? It sounds terrible!
  5. tehBoris
    tehBoris What's a Dremel?
    30 Jan 2011
    It could be a CRT...
  6. GoodBytes
    20 Jan 2007
    D-sub (aka: VGA) should not be used with LCD's or any digital display.
    Unless it's a CRT or something analogue, really don't use it. You'll get crap image quality.
  7. louist44
    louist44 Minimodder
    19 Jan 2011
    hah it is a 20inch DELL something or other. My budget was £1000 and I desperately wanted a GTX 560 which left me pennies for a monitor so yea it is pretty bad. The only other option I had was a broken monitor that is like 15" from my downstairs PC :thumb:
  8. GoodBytes
    20 Jan 2007
    1k! WOW.. I could get a Dell U2410 and a GTX 560, and perform a memory upgrade, and still have enough for a lunch and a chocolate bar.
    GTX 560 (260-280$)
    U2410 (500$.. 450$ if I force myself on negotiating a price)
    Memory upgrade.. (<130$ for 6GB)
    Lunch.. 5-10$
    Chocolate bar 0.50-1$
    Total: 921$ tops.
    you got ripped off, dude.. really.
    I would seriously see in returning that GPU, if it's not too late, and get a proper priced one, and now you can get a proper, respectful (to your eyes) monitor.
  9. louist44
    louist44 Minimodder
    19 Jan 2011
    this is a scratch build tho :( I have nothing to upgrade from.
    Needed literally everything, mouse OS ect and I wanted an SLI PSU so I can get another 560 when I needed it in the future (Cant wait to get more than 40fps in a game!??!) which made it cost so much. I think it was £930 without the monitor.
  10. GoodBytes
    20 Jan 2007
    OOOHHHHH, I thought you upgraded your GPU. Now it makes perfect sense. :)
    Haha!
