Hardware Edifier Prime USB Review
Discussion in 'Article Discussion' started by Lizard, 9 Jul 2011.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
  2. greigaitken
    greigaitken Minimodder
    26 Aug 2009
    they look so damn cheap - it's like they took a £5 set, crammed in a usb hub and said "well now they're 10 times better"
  3. nathandanielmorris
    nathandanielmorris What's a Dremel?
    23 Jan 2011
    Time well spent reviewing these then. Not.
  4. blackworx
    blackworx Cable Wrangler
    31 Jan 2008
    That's crazy - I have their MP300 2.1 set (now rebranded "Aurora" I believe) and they are simply the best portable 'speakers I have used. Rarely leave home without them, and I've heard a lot of praise for their other products.
    Going by this review, Edifier must have either made a bad misstep or stopped caring. I hope it's not the latter.
  5. dannyjh69
    dannyjh69 What's a Dremel?
    28 Oct 2010
    I agree with nathan, no point wasting your time reviewing something thats a piece of crap. might aswel give us reviews that we want to read and buy.
  6. Hakuren
    Hakuren What's a Dremel?
    17 Aug 2010
    Seriously, Edifier should stick to top quality products like S730D which I own. There is plenty of cheap rubbish on the market in every department. Don't sully such good brand with trying to please people without any requirements or taste. Leave that market for "no-name" brands.
  7. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    It doesn't quite work that way guys as we don't know a product is bad until we have tested it, and at that point you may as well complete the work off by writing a review.
    Otherwise you:
    a) End up with a publication only full of positive reviews, which 1) looks suspiciously like a paid-for review site, something that bit-tech isn't, and 2) doesn't educate readers why some products are bad
    b) Waste loads of time testing products you never write reviews of (in the case of these speakers we wrote a really quick review to waste as little time as possible).
  8. ssj12
    ssj12 Minimodder
    12 Sep 2007
    ya, my $15 walmart speakers, that I paired with the walmart 5.1 $80 speakers to make a 7.1 system, should sound way better then these POS looking things.
Tags: Add Tags
