Hardware Energy Efficient Hardware Investigated
Discussion in 'Article Discussion' started by Sifter3000, 24 Feb 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. p3n
    p3n What's a Dremel?
    31 Jan 2002
    nevermind missed the AMD cpus on the first page :>
  3. faugusztin
    11 Aug 2008
    One note about AMD - they undervolt very well, and default voltages selected by BIOS is in most cases very high. My X4 620 had a default voltage around 1.35V, yet my undervolting stopped at 1.12V (real, 1.1V in BIOS).
  4. Jezcentral
    Jezcentral Minimodder
    7 Sep 2009
    I may have my physics wrong, but (from the first page) if a particular product uses 50 per cent more power, but it's also twice as fast (100 per cent) at completing the task at hand, then doesn't this mean this is 33 per cent more efficient, not 50?.
  5. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    For this article, Efficiency = Speed/Power (electrical efficiency is actually [effective energy]/[power consumed]. I assume that [effective energy] is proportional to speed.)
    Letting a represent speed and b power,
    a/b = E
    2A/1.5B = 1.33 E
    So yes, math error in the article. ;)
  6. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    Any chance we can get some numbers on how much it costs to run a high powered PC per hour vs a low powered PC per hour? That would be pretty cool :)
  7. rickysio
    6 Jun 2009
    It depends on how much are you charged by your electrical company. They can't really do it, but perhaps they could do it in their context, that is, the London context. :D
  8. der_george
    der_george What's a Dremel?
    30 Jun 2009
    What about GPUs? was really looking forward to that bit... :( nevermind. The rest was quite interesting. I'm looking forward to more powersaving specials. :0)
  9. rickysio
    6 Jun 2009
    Just look at the reviews? They have the power consumption charts in each and every review, don't they?
  10. Jack_Pepsi
    Jack_Pepsi Clan BeeR Founder
    24 Apr 2006
    This is exactly the sort of article I like reading.
  11. amdavies
    amdavies What's a Dremel?
    11 Mar 2009
    For the UK, as a quick and dirty way to estimate things, I use 1 Watt per year = £1.
    So, the difference between leaving on a machine all the time drawing 50 Watts and one that draws 75 Watts is roughly £25 per year.
    So saving 10 Watts on a machine that you run for 4 hours a day is less that £2 over the course of a year. If this costs you £40 to achieve, you have to have over 20 years of use in order to justify it. The price of electricity almost certainly will go up, but I'm guessing it won't go up enough to justify the cost given the average lifespan of the equipment (whether through redundancy or failure).
    Efficiency does not equate to ultimately saving money, leaving the payback time out of equations is misinformation at best.
    (NOT having a go a Bit-tech or anyone in particular, it just seems likes it's fashionable within the "Green" industry to use possible savings rather than actual costs)
  12. mclean007
    mclean007 Officious Bystander
    22 May 2003
    Something fishy there... If product A uses 100W (0.1kW) of power and does 1 unit of work per hour, we can say its efficiency (workrate / power) is 1 / 0.1 = 10 units/kWh. If product B uses 50% more power (150W = 0.15kW) and is twice as fast (2 work units per hour), then its efficiency can be said to be 2 / 0.15 = 13.33 units/kWh, making it 33.3% more efficient, NOT 50% more efficient.
  13. Jipa
    5 Feb 2004
    EDIT: Fixed!
    Good article. I just noticed that my stupid HD4870 consumes over 70 W on idle. Loving how they cut the idle consumption with the HD5-series cards.
    EDIT: Also the sound card seemed to draw more power than I thought.
  14. rickysio
    6 Jun 2009
    Which is something Jezcentral and me have mentioned. ;)
  15. mclean007
    22 May 2003
    Oops, missed that. Sorry old boy ;)
  16. Guest-16
    Guest-16 Guest
    :thumb:
    We cover GPUs in depth, so I didn't bother :)
  17. faugusztin
    11 Aug 2008
    E8400+HD4870 -> i5 750 + HD4870 = 190->160W idle power usage
    i5 750+HD4870 -> i5 750 + HD5870 = 160->117W idle power usage
    It is funny that moving from dual to quad and from less to more powerfull graphics card results in smaller idle power usage. :)
  18. Kúsař
    Kúsař regular bit-tech reader
    23 Apr 2008
    I know AMD isn't as power efficient as Intel but you can still have some fun with reducing power usage. Just keep default CPU clock settings and create smartprofiles in AOD for demanding games. I'm using this(2.8GHz ->3.5GHz) for Crysis, CoD, Fallout 3 and it works like a charm. If only it was possible to turn on/off Cool'n'Quiet feature on-the-fly...
  19. rickysio
    6 Jun 2009
    But you can reduce power usage with Intel too!
  20. Dave_M
    Dave_M What's a Dremel?
    29 Jul 2007
    If your PC is idle most the time (like if you browse the web, listen to music, etc), then idle power draws are much more important to focus on. Athlon 240e is the clear winner here. It has the lowest idle power draw of any CPU I have seen. It uses LESS THAN 5 W !!! That includes VRM losses so its pretty impressive. http://www.lostcircuits.com/mambo//...task=view&id=70&Itemid=1&limit=1&limitstart=4 "the power numbers are un-adjusted gross input into the motherboard's voltage regulator module and are, therefore, inflated by roughly 30%. meaning that the CPU itself draws somewhere around 3-3.5W power in idle mode"
Tags: Add Tags
