PSU Enermax "Beeping" problem with ATI 3870-X2
Discussion in 'Hardware' started by ComputerKing, 17 Mar 2009.
  1. ComputerKing
    8 Sep 2006
    Hi
    I got myself some new hardware ;)
    I face 2 things now
    First MY Enermax PSU keep Beeping......
    Second My Q9450... First 2 cores give higher temps than the other 2 ... 10 degree difference ...
    I checked the cooler and thermal paste and did it like 5 times same thing...
  2. ComputerKing
    8 Sep 2006
    This is my PSU model : ENERMAX GALAXY EGA1000EWL
    My new hardware list
    Q9450
    4GB 1066
    3870X2
    EP45-UD3LR
  3. Diosjenin
    Diosjenin Thinker, Tweaker, Et Cetera
    14 Jul 2008
    It's not unheard of for the cores of Intel Core 2 Quad processors to be vastly different temperatures in pairs. This is primarily because Core 2 Quads aren't "native" quad-core CPUs - they're two different physical processors jammed together under one heatspreader. Ideally they'd give equal temperatures, but occasionally one die will be of poorer quality than the other and give off far more heat. End result: Cores 1 and 2 are 5-10C lower than Cores 3 and 4, or visa versa.
    Don't know about your PSU/GPU, though.
    - Diosjenin -
  4. verdi
    verdi What's a Dremel?
    12 Feb 2009
    it would help to know the beeps mate. are they in a pattern or is it constant. When I installed a brand new 8800 GTX it beeped. I could POST and browse but anything that became even slightly graphics intensive would shut me down. Card was naffed and new one worked a treat. Also worth bearing in mind that video POST beeps are normally one long 3 short (well that's what google told me) but sometimes it changed in my case. All rosy with new card in though.
  5. ComputerKing
    8 Sep 2006
    It's 2 beeps pattern and keep going for ever ( with red light led )
  6. Guest-16
    Guest-16 Guest
    LED:
    Red Light
    Buzzer:
    Tow Beeps Interval:
    Information:
    1. Power supply abnormal, protection circuit activated*.
    2. Connector terminals are short-circuited.*
    Contact Enermax and see what they say.
  7. ComputerKing
    8 Sep 2006
    Bindibadgi
    No that is the wrong state i'm on this :
    Light : Red Light
    PSU Status : On
    Buzzer: Tow Beeps Interval
    Information:
    1. PG ( Power Good ) signal abnormal
    2. System loading lower than Psu minimum output load requirement ** ( which is impossible )
  8. Guest-16
    Guest-16 Guest
    Take it all out the case and try? Maybe it's shorting.
  9. ComputerKing
    8 Sep 2006
    Hum
    I did same thing. No shorting.
  10. ComputerKing
    8 Sep 2006
    Replay from Enermax Deutschland Support... BS
  11. Krikkit
    21 Jan 2003
    Why is that a bs? He's saying that unless you've changed something else in there the PSU is at fault, and you should send it back to your supplier for RMA.
    What were you expecting? "We'll send an engineer out immediately" ? :eyebrow:
    Just send it in for replacement, see if it helps.
  12. ComputerKing
    8 Sep 2006
    you kidding me ?
    Buddy Did you notice i live in Dubai ? In other words UAE ?
    We don't have any one sell enermax things any more... I bought mine from a shop that had 5 that the owner brought from USA or UK not sure and he was selling them here for alot..... that shop closed from 1 year ...
    So now you know why this is BS ? I can't RMA my PSU
  13. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    In all fairness, that is your problem mate...
    Besides the overly correct helpdesk-speak, the content of the mail seems fine. They need to get their hands on the unit to do any research no matter what.
    If you cannot return the unit, try finding somebody who knows his electronics, and fix the thing yourself. If you dont plan on using warranty, there's no loss in voiding it, right? ;)
    I'd start by looking at the 8-pin cable itself. One tip: Try to find one of those 2x molex to 8-pin PCIe converters, or fabricate your ow in a worst-case scenario.
  14. ComputerKing
    8 Sep 2006
    yeah brother
    the problem coz 8 pin cable and 6
    see my new vga use 6 and 8 pin cables at same time
    when i used 6 and 6 it beeps but computer works npp
    when i did my own 8 pin cable it keep beep and computer works np
    so i don't know if i'm doing the wrong 8 pin cable or what
    ( Down 4 yellow Up 4 Black ) that how i did it
    Side note : I don't flam or hate enermax or any one replay to me... it's just people don't understand my situation most of times :(
  15. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    erm... isn't that the 8pin CPU connector?
  16. ComputerKing
    8 Sep 2006
    o_O no it's not ?!
    coz the 6 pin is 3 yellow down / 3 black up
    i googled and found that 4 pin vga cable is like this
    4 yellow down / 4 black up
    I didn't play with first 6 pins ... I just added more 2 pins in same order
  17. Krikkit
    21 Jan 2003
    So it's Enermax's fault you bought a PSU you're not prepared to RMA? Surely there's a retailer close to you who stocks Enermax stuff? They might be able to help you.
    Send an email back to Enermax too, they might help you.
  18. ComputerKing
    8 Sep 2006
    i did
    and i'm sure that no one sell enermax here. brother i scanned dubai shop by shop...
  19. Krikkit
    21 Jan 2003
    Ask them?
  20. ComputerKing
    8 Sep 2006
    no i didn't ask C & J but i will give it a try now... It's far away in Deutschland
