Epiae - HTPC
Discussion in 'Project Logs' started by swf, 25 Dec 2004.
  1. swf
    swf What's a Dremel?
    25 Dec 2004
  2. Brubacker
    Brubacker What's a Dremel?
    23 Oct 2004
    Woow
    sweet dude !!
    although, won't it blind you when you're watching a movie ? :hehe:
    Greetings,
    Brubacker
  3. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    Whn i click the link and sa this i was like :eeek: :jawdrop: :eeek: :jawdrop: :eeek: :jawdrop: :eeek: :jawdrop: :eeek: :jawdrop: :eeek: :jawdrop: :eeek: :jawdrop: :eeek: :jawdrop: :eeek: :jawdrop: :eeek: :jawdrop: *twitches violently from smilie overload and sweetness of the lighting*
    *after five min of twitching, regains contol*
    That looks SAWEEEEEEEEEET. I have never seen anything like it and have watched it since the begining. One of the best mods i have seen. All though i would say to put something over that fan so things dont fall in.
    More pics would be cool too.
  4. AutoExec
    AutoExec What's a Dremel?
    31 May 2004
    great build, just keep that fan clear of kids and pets :D
  5. infered101
    infered101 What's a Dremel?
    30 Oct 2004
    Dont mean to be a nit picker but is that tv card you ordered have a hardware encoder. By this i mean does it convert the video on the card or does the software on the computer do this. IF it uses software you might run into a problem as the epia doesnt have the power to convert the video. On live tv it will be choppy and someitmes not work and you will have real problems if you want to record tv 2. I know the leadtek isnt a hardware enoder infact the only cards i know that are is some ati cards and the hauppage pvr series.
    Just noticed it was a usb tuner not sure bout that
  6. Yelrad
    Yelrad What's a Dremel?
    30 Dec 2004
    very nice how much you think its worth jw?
  7. Mr. Red
    Mr. Red Minimodder
    1 Aug 2003
    Very nice mod. My retarted self would need some protection on the fan *flashback of hand getting nicked by a fan*, but it seems to fit nicely with your design. I assume it is a sucker?!
    While a dremel and drill may get you more respect, I personally think machine cut parts look much better! And besides, its still your design that is being cut. Keep up the good work!
  8. Redd_Herring_1974
    Redd_Herring_1974 What's a Dremel?
    3 Sep 2004
    very neat and clean....i love it....subscribeing now :thumb:
    and as far as was mentioned eralyer dont sell your self short i would put this up with any of the other great mods around here...just 'cus you didnt do the machining yourself souldent matter much because a well thought out and executed desinge are what really matter in my opinion its ez to design something as simple and unimaginative as just a box with windows and blow holes...but its really hard to desinge something that really looks so asteticly pleasing and professional as this though...keep up the wonderfull work :thumb:
  9. NoCoolOnesLeft
    NoCoolOnesLeft What's a Dremel?
    31 Dec 2004
    looks good so far. That fan looks a little scary.... :clap:
  10. swf
    25 Dec 2004
    Thank you all :D.
    @infered101
    The new Adaptec USB Card has MPEG-2 Hardware Encoding.
    I like the idea of a second color, so I need input :D, which color to choose. All suggestions are welcome.
  11. Brubacker
    23 Oct 2004
    Add yellow and red, then you can combine the different colors and get all the colors of the rainbow :p
    (using a variable resistor (like in a rheobus :p ) to make a color brighter ... )
    just my 2 cents ...
  12. tm36usa
    21 Jan 2004
    Just add some red. Blue and red mix nicely together.
  13. eclectik
    eclectik What's a Dremel?
    2 Dec 2004
    More pics please :dremel: :clap:
  14. uwannabigmak
    uwannabigmak What's a Dremel?
    30 Dec 2004
    the primary colors of light are red, blue and green. im replacing all the leds on my fans with rgb ones so i can get any color. btw, does anyone know if u can put cc's or leds on a dimmer(eg rheobus)?
  15. swf
    25 Dec 2004
    There are already two potentiometers on the back, one for the fan and one for the LEDs. :naughty:
  16. THDBASED
    THDBASED What's a Dremel?
    30 Dec 2003
    Where did you get that plexi? Online available or just a local shop?
    BTW, nice mod!
  17. swf
    25 Dec 2004
    Ebay
  18. star882
    star882 What's a Dremel?
    19 Mar 2003
    Actually, the signal is already encoded. You only need the encoder if you want to reencode to a different format or resolution.
    I have an old Pentium Pro that works fine saving HDTV, without any hardware encoder.
  19. Jokkocze
    Jokkocze What's a Dremel?
    16 Dec 2004
    looks really good! keep up the good work!
  20. Eran
    Eran What's a Dremel?
    6 Nov 2004
    how did you connect the mobo to the plexi surface without drilling the plexi itself, and how did you designed the power button ?
