Bits Episode 5 of the CPC and bit-tech Podcast
Discussion in 'Article Discussion' started by Sifter3000, 21 Aug 2009.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. rainbowbridge
    rainbowbridge Minimodder
    26 Apr 2009
    Bit tech should put together an all time/current top ten best game music from last nijna to GTA IV.
    No old school demos as they would just fill the whole chart like the sims :D
    Game music rules.
  3. Bauul
    Bauul Sir Bongaminge
    7 Apr 2007
    You weren't joking about another copy of Zeno Clash were you? Lol.
  4. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    How do i enter the comp, i missed the details for contacting you guys!
  5. Guest-16
    Guest-16 Guest
    podcast @ custompc . co. uk
  6. Burnout21
    9 Sep 2005
    Thanks binid, i just PM'd Alex before your reply. Emailing now.
  7. wyx087
    wyx087 Multimodder
    15 Aug 2007
    it is Field Programmable Gate Array. they are the best pieces of hardware known to man. hope graphics chips comes with those in the future. (but then, why would we buy from nVidia/ATI when Xilinx/Altera have been making great FPGA for years)
    on the point of Lucid Hydra. it is completely possible for 100% performance scaling. let's talk numbers:
    gtx280 vs 8800GTX, about 70% faster.
    240 vs 128 shaders, 87% more
    1296 vs 1350 shader clock speed, a little bit slower per clock
    comparing the shader numbers along shows should be about 70% speed difference. but there's also ROP, texture fillrate and other stuff needs considering, so real world difference varies.
    on the point about pairing different cards, not sure about cross brand. but for same-brand cards, the shader architecture should be exactly the same, 210 uses the same shader pipeline as 280, just different amount of it.
    on the same principle, it can be said that as long as 2 different cards work together, then all others should do the same.
    also, due to it's a hardware implementation, it is possible to be operating system independent. this is also why i kept wanting BIOS based fan controller, it is a hardware based implementation, so not OS dependent.
  8. mrbens
    mrbens What's a Dremel?
    15 Aug 2009
    ha the music at the start made me laugh, not cos it was bad but because the bad timing the first guy started talking and then quickly faded it out, you'll never make a DJ ;)
  9. shaffaaf27
    shaffaaf27 The budget builder
    3 Jun 2008
    umm isnt phenom pronounced feenom?
Tags: Add Tags
