got this last nite never noticed it before [09:35:49] Run: exception thrown during GuardedRun [09:35:49] Run: exception thrown in GuardedRun -- Gromacs cannot continue further. [09:35:49] Going to send back what have done -- stepsTotalG=10000000 [09:35:49] Work fraction=0.7327 steps=10000000. [09:35:53] logfile size=9056 infoLength=9056 edr=0 trr=23 [09:35:53] - Writing 9592 bytes of core data to disk... [09:35:53] Done: 9080 -> 3279 (compressed to 36.1 percent) [09:35:53] ... Done. [09:35:53] [09:35:53] Folding@home Core Shutdown: UNSTABLE_MACHINE [09:35:57] CoreStatus = 7A (122) [09:35:57] Sending work to server [09:35:57] Project: 10112 (Run 203, Clone 2, Gen 34) [09:35:57] + Attempting to send results [November 14 09:35:57 UTC] [09:35:57] Gpu type=2 species=0. [09:35:57] + Results successfully sent [09:35:57] Thank you for your contribution to Folding@Home. [09:36:01] EUE limit exceeded. Pausing 24 hours. anyone have any ideas?? System info:-
If you're getting lots of EUEs then the chances are that one of more components in your PC is either overclocked too much or dying, so corrupting data. If your CPU(s) or GPU(s) are overclocked trying backing off a little on the overclock and try folding again.
I would suspect that and thanks for thee quick response Lizard I think its the GPU ive been pushing it hard now backed it off now and see how that goes Was reading a thread on another folding forum and firmware also come into play too?? What Firmware is everyone running at the moment??
Ah, spot on. Are you folding with that as well, or just on the GPU? The extra heat in the case may cause issues, but the Q6600 is a nice Folding chip. Are you running any extra cooling on your 9600GT (aftermarket cooler, side-panel fans, etc)?
there both Watercooled so that really shouldnt be an issue only have one smp client running locked to one core and the gpu client thats it
How come you've got the SMP client locked to one core? Would a standard client not be more suited to that? Or better yet, locking the SMP to 3 cores and leaving one free for the GPU?
Use the SMP client on the Q6600 with the tag -smp 3, and you'll use 3 cores instead of the one. Should mean you're going fast enough on those units to qualify for much more points (there are SMP bonuses for quick finishes). Leave the one core free for the GPU client, so you're not impacting it.
i am using set affinity to monitor and control cores so shall i just lock the smp to core1,2,3 and leave the gpu at core 0?? Sorry for all the bone Q's but been out a while and things have changed somewhat lol
That'd do, yeah. Or should, anyway - I don't see why not. One of the more expert Folders will be along at some point to read this, I'm sure.
Probably best to use all four cores for SMP but raise the priority of the GPU core by setting it to 'low' in the client configuration. This way the GPU PPD will not be affected.
Seems to be working fine as it is got a work packet on there worth around 191 points been working on it all night since 2100hrs and it will be done around 1500hrs takes so long lol GPU on the other hand is saying that am getting a ppd of 17k WTF
That's very odd. I'm starting to get the same message on my GPU. I reverted it to stock and it still fails. Any Ideas why it might be? Log file says that every time: Code: Completed 2500001 out of 50000000 steps (5%). [23:46:44] Completed 3000000 out of 50000000 steps (6%). [23:48:03] Completed 3500000 out of 50000000 steps (7%). [23:49:21] Completed 4000000 out of 50000000 steps (8%). [23:50:41] Completed 4500000 out of 50000000 steps (9%). [23:52:00] Completed 5000000 out of 50000000 steps (10%). [23:53:19] Completed 5500000 out of 50000000 steps (11%). [23:54:37] Completed 6000000 out of 50000000 steps (12%). [23:55:54] Completed 6500000 out of 50000000 steps (13%). [23:55:54] mdrun_gpu returned 52 [23:55:54] NANs detected on GPU [23:55:54] [23:55:54] Folding@home Core Shutdown: UNSTABLE_MACHINE
That used to mean the ram was dying on my 8800GT's. Try a client reinstall & driver update then test the card through 200 runs of the crysis benchmark to see if it crashes.
now thatis strange maybe a few iffy work jobs pushing the old cards to death or telling me i need to get new kit lol
One of my new GTS 450s has been getting NANs. I've just turned it off for a few days, in case there were some rogue WUs being pushed out - I don't want the hassle of RMAing. Not overclocked, all case temperatures seem OK.
Anyone seem these yet?? Currently Running Projects Project Number Server IP Work Unit Name Number of Atoms Preferred (days) Final deadline (days) Credit Frames Code Description Contact Kfactor 2494 171.65.103.160 p2494_system 97093 42.00 93.00 905.00 100 GROMACS Description ppetrone 0.00 2633 171.67.108.24 p2633_CGVES 102731 1.20 2.00 235.00 100 GRO-A3 Description kasson 3.10 2684 171.67.108.22 p2684_SINGLE VESICLE in water 1096433 4.00 6.00 8955.00 100 GRO-A3 Description kasson 26.40 2685 171.67.108.22 p2685_SINGLE VESICLE in water 1089419 4.00 6.00 8955.00 100 GRO-A3 Description kasson 26.40 2686 171.67.108.22 p2686_SINGLE VESICLE in water 1098185 4.00 6.00 8955.00 100 GRO-A3 Description kasson 26.40 2692 171.67.108.22 p2692_Generated by trjconv : SINGLE VESICLE in water t= 66000.00000 1098185 4.00 6.00 8955.00 100 GRO-A3 Description kasson 26.40 there some big ass jobs lol
