Hardware EVGA nForce 650i Ultra
Discussion in 'Article Discussion' started by Tim S, 19 Jun 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    cheap and weak.... remembers me my evil asrock board, how i hate it for being weak, at least it had lots of features. that back side looks very barren and it is greeeeen, my old asrock was dark blue and was cheaper.
  3. DougEdey
    5 Jul 2005
    Cheap board should have parrallel and serial on the I/O at least, it'd save money from running extra cables and making extra PCI-blanking plates
  4. eek
    eek CAMRA ***.
    23 Jan 2002
    Not a bad review, but I found the gaming section a bit weak. I understand why it was coupled up with a budget card and so on, but given that not a single other board it was compared with shared the same card, it failed to give a proper indiction of its relative performance. It seemed almost pointless including the results from other motherboard/card combos as they added nothing IMO.
    If you're comparing gfx cards against each other then it makes sense to test a variety of cards.
    When comparing motherboards surely it makes sense to keep as much as you can the same, including the gfx card - especially when looking at game performance? The fact that it got beaten by every other board was not surprising given they housed a 7900GTX.
  5. kenco_uk
    28 Nov 2003
    Aye, that does seem a bit of a strange decision.. why not do another run of gaming benchmarks with the 7900 card plugged in?
    A budget setup doesn't necessarily mean *everything* has to be a few notches behind technologically.
  6. Guest-16
    Guest-16 Guest
    I see your point, I just don't have anything in the lab to compare it to. The Gigabyte and board has gone back already and I only just found the MSI P6N Platinum again.
    The 650i Ultra is specifically designed for the 7600GS.
    In hindsight I should have tested with an E6300 and 7900 GTX, perhaps, or given I found the MSI far sooner I might have had time to put that together with a 7600GS and E6300.
    The gaming performance in high res is GPU limited anyway, if anything the 7600GS is a representation in there.
    It's a point noted, but I find it hard to review mainstream boards since companies tend to want to keep the hardware.
    If you really want, I can throw the board back on when I have time and do a 7900 GTX and E6300 with the 650i but the MSI will take far longer since I've got to start from a scratch installation.
  7. Nature
    Nature Minimodder
    21 Nov 2005
    I like the position of the Pci slots on this here board. Moast of Nforce 500-600 series boards the pci's slots are smushed together, near a potential dual slot GPU, or in the middle of two pci express lanes. This one is breazy-Mc-easy. Plenty ov room for tv tuners, sound cards, and what have you.
    I don't consider this board a bargain for US pricing... Considering a 680 ultra from EvGA is 25 bones more... 25 dollars is not a lot when you weigh in what Joe consumer gets on a 680 ultra.
    Flawless review, and the new color-coated graphs have grown on me. I'd really like to see a nice laptop review from you guys soon, the last one was from rock and had a whole lotta creepy skulls on it...
    note: for those of you using a mac, you can make that badgi's avatar go in slow motion if you click on the scroll bar really fast like... :D
  8. ./^\.Ace./^\.
    ./^\.Ace./^\. What's a Dremel?
    7 Jun 2007
    I just looks like it is missing a lot of stuff. It looks like a low end Intel mother board :yawn:
  9. trig
    trig god's little mistake
    10 Aug 2006
    gimme
  10. keith_j_snyder2
    keith_j_snyder2 What's a Dremel?
    22 Apr 2006
    Maybe for a sec...i thought rich will use 8600 GT or GTS.I mean that will give the better idea for the latest things.
  11. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    hmm.. i like.. I still run an EVGA 7800GS AGP on a p4p800s-e mobo. might be time to upgrade to this board and a 8something series card. Couple that with a Samsung or LG 22" inch tft and that should keep me happy for a few years. just dont know which gfx card. 88 or 86.
    And i like it oldskool (yes skool ;) ) watercooled ofc.
  12. Pie_uk
    Pie_uk British beef, in Britain
    6 Apr 2005
    yep, me flicking through it thought somethings not right here. then found out once i read though it carefully.
    strange way of testing gaming performance, almost pointless imo
  13. qupada
    qupada What's a Dremel?
    7 Jun 2006
    I wondered about that too, surely it's cheaper to solder a serial port onto the board than make a PCI bracket with cable. At least they haven't just disposed of it entirely I guess, some of us with serial port UPS's don't want to buy USB>RS232 converters.
    The parallel port on the other hand? Good riddance I say.
  14. Guest-16
    Guest-16 Guest
    E6300, 7900 GTX scores added for comparison :) :thumb:
  15. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    i sure as hell hope theres a labelling mistake on the photoshop graph
  16. Tim S
    Tim S OG
    8 Nov 2001
    :worried:
  17. kenco_uk
    28 Nov 2003
    woot! Crikey, they're quite telling!
  18. groucho
    groucho What's a Dremel?
    22 Jul 2007
    I can't find anything in documentation about a connector on this mobo for the PC case speaker but I see a 4-pin connector near the audio connectors in the corner of the board that fit the connector that my case has for the speaker. Any ideas?
    Also, if I want to connect my CD/DVD player to the mobo to get audio (with either a 2 or 4-pin connector) can I do that? Again, nothing in documentation. In my other systems without integrated audio, the sound card typically has a place to plug this connector in.
  19. Guest-16
    Guest-16 Guest
    PC Speaker? Why do you need it? Boot problems? It'll likely be on the front panel pin out. I've not seen anyone use an old 4-pin connector for the DVD/CD player in YEARS, now it's all done over the normal IDE/SATA digital connection in all OS' and software I can think of. Or do you mean a separate external devise, like a stand alone?
Tags: Add Tags
