News EVGA preps firmware update for ACX 3.0 overheating flaw
Discussion in 'Article Discussion' started by Gareth Halfacree, 2 Nov 2016.
  1. Gareth Halfacree
    4 Dec 2007
  2. russ555
    russ555 What's a Dremel?
    24 Apr 2009
    EVGA once again showing why they are a first choice for PC components.
  3. Gareth Halfacree
    4 Dec 2007
    ...Is this sarcasm? I genuinely can't tell.
  4. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    I think they've handled it very well. No excuses, no burying of heads in sand. They've even said they'll honour any repair required if users damage anything whilst fitting the thermal pads.
  5. Harlequin
    Harlequin Modder
    4 Jun 2004
    or maybe they shouldn`t cheap skate on the amount of vrm`s the card actually needs - you know , like gigabyte allegedly do with a new revision of a motherboard.....
  6. Impatience
    Impatience Minimodder
    6 Apr 2014
    ^Even if they do it wrong and the card does burn out, they will still honour the warranty! Now that's true customer service for peace of mind IMO..
  7. The_Crapman
    5 Dec 2011
    Considering this is apparently only related to using furmark and not 'normal' usage, they could easily have just said "don't use furmark, our cards weren't designed or intended to have the bejesus ragged out of them on this manner" and is the kind of 'it's not our fault' excuse we're used to seeing these days . Furmark is like checking your erection works by sticking it in a hornets nest, so fair play to them for doing something about it and not trying to sweep it under a rug.
  8. Vault-Tec
    30 Aug 2015
    The EVGA built in stress test with Precision X is Furmark dude.
    I've seen these VRMs and they are almost impossible to actually see. They are absolutely tiny. The issue is caused because they don't have any heat transfer pads on the back of the GPU carrying to the back plate. So if you overheat the VRMs they burst into flames.
    EVGA have said this only affects cards made before Sept 2016, so they have somewhat acknowledged that there is an issue and have a serial checker to see when your card was made etc.
  9. The_Crapman
    5 Dec 2011
    LOL! Guess they couldn't claim that then. :hehe:
  10. Vault-Tec
    30 Aug 2015
    They've been pretty honest about it tbh. This is a pic of the VRMs in question. For E-peen 'a' bility it's definitely tweezers and a magnifying glass :D
  11. russ555
    24 Apr 2009
    No, not sarcasm :)
    I've heard nothing but praise for EVGA and their warranty program. I don't actually have any EVGA stuff at the moment but when I upgrade anything that can be EVGA will be.
