Hardware Exploring CPU Cooler Design and Testing with Cooler Master
Discussion in 'Article Discussion' started by Combatus, 28 Nov 2014.
  1. Combatus
    16 Feb 2009
  2. Troglodyte
    Troglodyte What's a Dremel?
    29 Mar 2011
    Looking forward maybe moreso to the PSU tour. Very interesting article and whilst Coolermaster would be my first choice for case maybe not so much for CPU coolers. Would love to see Bit-tech with a similar testing system ; hope this happens !!
  3. Xir
    Xir Modder
    26 Apr 2006
    Trying to get the physics here.
    To have the water enter the gasphase at 30°C they're running at ~0,05 Bar I guess.
    As long as it it "boiling" the temperature cannot rise. But coolers don't run at 30°C... hmmmm
    Well, the steam does change the pressure inside the heatpipe...rising pressure (>0,05 Bar) means higher boiling point. Recondensating steam lowers the pressure, and means a lower boiling point.
    So somewhere we have a point of equilibrium....but at more than 30°.
    right? :D
    Ooooh, unless there's very little water in the system, so little that none of it is liquid. if all fluid inside the heatpipe is in gasphase than we're...iso..errrr...constant volume...changing pressure...
    My god it's been long since I've had Thermodynamics :brrr:
  4. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    I'm no physicist, but wouldn't 30 mbar be closer to a gas phase @30°C
    The cooler wouldn't be running at 30°C only the heat pipe closest to the heat source would need to hit 30°C some of the heat pipe needs to remain under that to allow for recondensing.
Tags: Add Tags
