Cooling Fans remain on when computer is turned off
Discussion in 'Tech Support' started by Goatee, 16 Oct 2019.
  1. Goatee
    Goatee Multimodder
    19 Apr 2015
    I have a dell optiplex 9020 that has an unusual problem.
    The unit works fine, powering on and running normally. No issue with stability and performs as expected.
    However, as soon as power is applied to the unit (i.e. power cable plugged in) the fans spool up to full power. The fans remain on 100% until the power button is pressed, following which they spin down and act normally.
    I have updated all drivers and bios, tried disabling C-states and changing any remoterly appropriate bios options.
    Anyone got any ideas?
  2. The_Crapman
    5 Dec 2011
    A) Haunted
    B) Malfunctioning turbo timer
    C) Malfunctioning PSU
    Any idea how it's wired?
  3. Shirty
    18 Apr 1982
    Reset CMOS? Flash BIOS?
  4. RedFlames
    23 Apr 2009
    This is more or less the troubleshooting step for macs when they do the same thing [which is often].
  5. Goatee
    Goatee Multimodder
    19 Apr 2015
    Im thinking A, possibly C.... not sure what B is.
  6. Goatee
    Goatee Multimodder
    19 Apr 2015
    Tried both, no change
  7. RedFlames
    23 Apr 2009
    it's something that keeps the car engine running to allow the turbo time to cool down properly, avoiding damage. - linky: https://en.wikipedia.org/wiki/Turbo_timer
    In a pc context some PCs/PSUs keep the fans spinning for a few minutes after the pc shuts down to aid cooling.
  8. Shirty
    18 Apr 1982
    Does the issue occur without the boot drive connected?
  9. Goatee
    Goatee Multimodder
    19 Apr 2015
    Yep, its weird. More I think about it must be PSU.
  10. Goatee
    Goatee Multimodder
    19 Apr 2015
    Ah, makes sense. Still think its haunted.
  11. yuusou
    yuusou Multimodder
    5 Nov 2006
    Are the fans hooked directly to the PSU or to the board? If former then if the PSU sends out power regardless of motherboard, that'll be the reason.
  12. Goatee
    Goatee Multimodder
    19 Apr 2015
    Board, separate headers
  13. yuusou
    yuusou Multimodder
    5 Nov 2006
    There has to be some weird ass bios setting then. Or perhaps even a jumper.
    Goatee likes this.
  14. Goatee
    Goatee Multimodder
    19 Apr 2015
    bios setting have been fiddled with but a jumper is a new angle! Will see if I can get the usff 9020 motherboard layout and see if a jumper needs tweaking!
  15. RedFlames
    23 Apr 2009
    The Bios for the 9020 has a setting called 'Fan Control Override', which if enabled, cases the fans to go at full tilt all of the time. It's in the 'Power Management' section.
    ...source - R-ing TFM [Page 37]
  16. Goatee
    Goatee Multimodder
    19 Apr 2015
    Tried that. It only impacts when the PC is turned on.
    It just makes the board sound the same when powered on and off.:wallbash::wallbash::wallbash:
  17. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    Is the CMOS battery still good? Holding the date and settings in the BIOS?
  18. Goatee
    Goatee Multimodder
    19 Apr 2015
    Yep, battery is fine.
  19. veato
    veato I should be working
    15 Jan 2010
