Other Faster than the speed of light?
Discussion in 'General' started by tristanperry, 22 Sep 2011.
  1. Herbicide
    Herbicide Lurktacular
    27 May 2004
    Going by the words (not the equations) in the abstract it seems that they're measuring the results with greater accuracy (precision?) than the numbers they were using for the speed of light in a vacuum.
    I think.
  2. Showerhead
    Showerhead What's a Dremel?
    11 Jan 2010
    Actually it makes no difference if you measure c with or against the rotation of earth. The speed remains the same.
    One good argument i read about this observation is that we measure the neutrino burst from a supernova just after the EM burst suggesting they are slower than light speed. I'd wait for this to be properly verified before getting too excited.
  3. LennyRhys
    LennyRhys Oink!
    16 May 2011
    The speed of light has indeed been measured many times, but it is still only assumed that the special theory of relativity is correct and therefore that the speed of light is constant; such an assumption cannot be empirically verified.
  4. Modsbywoz
    Modsbywoz Multimodder
    14 Oct 2009
    Me too.
    Think all of the theories described within it will have to be re-thought if this proves to be correct.
  5. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    If special relativity is proved to be incorrect then it almost certainly implies maxwells equations are incorrect which I believe invalidates GUT. This effectively rewrites the last 100 years of theoretical physics. It's a scary thought, but remember that this is exactly what happened 100 years ago.
    My copy was misprinted and became incomprehensible about halfway through. Bit of a bummer.
    We should all remember that Neutrinos are highly invisible particles; it takes 60m deep wells linesd with detectors to detect a handfull every day when something like a billion of them pass through your eyes every second.
  6. sicone
    sicone What's a Dremel?
    6 Oct 2004
    Personally I think this is an issue of margin of error. No measurement can be 100% accurate, but with something travelling so fast even a 0.01% margin of error throws the SoL out by almost 30,000 m/s! Of course, the same applies to how they measured the speed of the neutrinos
  7. Tibby
    Tibby Back Once Again
    9 Oct 2005
    A bartender says "We don't serve Tachyons in here."
    A Tachyon walks into a bar.
    :D
    Ontopic: this is pretty cool if it stands up to scrutiny.
  8. sb1991
    sb1991 What's a Dremel?
    31 May 2010
    The speed of light is known much more accurately though. In fact, the speed of light is defined as 299,792,458 m/s, and the length of the meter has an uncertainty on the order of one part per billion (I think). It's much more likely that there's some systematic error here than that the result is due to imprecise measurements (note the distinction between accuracy and precision).
  9. uz1_l0v3r
    uz1_l0v3r What's a Dremel?
    22 Sep 2009
    http://en.wikipedia.org/wiki/Speed_of_light
  10. Krikkit
    21 Jan 2003
    Let's make sure we're talking about the correct Speed of Light here, first in the practical sense - i.e. what we know is that the speed of light in a vacuum is 299,792,458 m/s. Many things work on it, and we've measured and defined it so exactly that it cannot be adjusted or incorrect.
    Second, in the sense of Relativity, this theorised absolute speed that cannot be exceeded or even reached by particles with mass. It's called the Speed of Light, but if we've found particles which can travel faster, it would have to be the Absolute Speed or something. That's what is possibly (but very unlikely) broken.
    Personally I'm expecting it to be a systematic experimental error, rather than a fundamental flaw in particle mechanics, but I'm quite prepared (and excited) by the possibility that I'm wrong.
    What's the Brian Cox/Jeff Forshaw book like? Do they come across as enigmatic and interesting people through the text? Jazzy Jeff Forshaw was the single most interesting lecturer I had at uni, he had a very uncluttered view on things which was quite enlightening.
  11. Ending Credits
    4 Jan 2008
    Personally I can't see special relativity being fundemantally wrong given how often it is used for practical applications (GPS has to take special relativity into account). Bu as I said before, that's not solid proof that we're right.
    Hopefully what this does is open up whole new branches of science to explore.
    It was good for the parts that we're all jumbled up in my copy although they did seem to think their reader was incapable of simple arithmetic.
  12. Toka
    Toka Minimodder
    19 Nov 2006
    Some cool stuff here about the measurement of some physical properties (and their corresponding theoretical predictions). Its well worth a listen even though not really related.
    Edit: Hrm - looks like the videos are a bit broken atm - shame as they are properly awesome.
  13. RedFlames
    23 Apr 2009
    *Nothing* travels faster than bad news...
  14. Ending Credits
    4 Jan 2008
    Or Usain Bolt
  15. supermonkey
    supermonkey Deal with it
    14 Apr 2004
    :hehe:
    Here's one I read in the newspaper this morning:
    There was a neutrino so bright
    Which could travel far faster than light
    It went out one day
    In a relative way
    And came back the previous night
  16. Edwards
    Edwards Minimodder
    8 Oct 2010
    If they have incorrectly measured the distance between the points because the target is moving closer or further away from the origin during travel, when they have taken the distance to be the physical distance between the two at a given point in time, then they can't have an accurate calculation of speed, unless I'm missing something very basic.
  17. Ending Credits
    4 Jan 2008
    Basic as in general relativity?
    Although I'm not sure what applies in a rotational reference frame.
    EDIT: Basically we can assume the earth is stationary and the universe is moving if we want.
  18. Showerhead
    11 Jan 2010
  19. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Sounds like something Sheldon would say, :D
  20. LennyRhys
    LennyRhys Oink!
    16 May 2011
    BAZINGA!
