News First Fermi card pictured
Discussion in 'Article Discussion' started by Tim S, 30 Sep 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
    4.54billionyears likes this.
  2. capnPedro
    11 Apr 2007
    I like the physicist naming scheme :).
  3. Threefiguremini
    Threefiguremini What's a Dremel?
    13 Sep 2009
    If the 5870 is the bat-mobile then this is definitely KITT
  4. Ryun
    Ryun What's a Dremel?
    28 Apr 2009
    You're not supposed to touch the PCI-E pins, Huang!
  5. bowman
    bowman Minimodder
    7 Apr 2008
    Does anyone know if the cards are functional in NVIDIA's tests yet or are they just mockups?
  6. kenco_uk
    28 Nov 2003
    Oh great, so the power socket's on the end of the card, rather than the side. We'll be buying cases resembling sideboards next.
  7. Goty
    Goty Minimodder
    13 Dec 2005
    Raise your hand if you think it's entirely possible that this is a blank PCB with a cooler bolted to it!
    =P
    On the bright side, do I only see one PCI-E power connector there? THAT would be pretty impressive if this card turned out to be GT300.
  8. Tim S
    Tim S OG
    8 Nov 2001
    They've shown some particle simulation demos on the GPUs... silicon is early, but working.
  9. GoodBytes
    20 Jan 2007
    He has an uncountable number of these at home.. do you think he remotely cares about holding it properly. :lol:
  10. Dave Lister
    Dave Lister Minimodder
    1 Sep 2009
    Look's and sound's impressive, i wonder if it will play crysis smoothly with everything maxed out.
  11. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    Damn, you beat me too say that >.<
  12. Elton
    23 Jan 2009
    Interestingly that looks like the 8800GT or the 9600GT equivalent of the GT300..
    No way it has 1 power plug.
  13. GoodBytes
    20 Jan 2007
    You right, it needs a motherboard plug to make it work, which is on top of the card ;)
  14. Elton
    23 Jan 2009
    Ah! I never would've guessed. :duh:
  15. salesman
    salesman Minimodder
    29 Apr 2007
    Looks like Huang has been hitting the gym.
  16. Elton
    23 Jan 2009
    For some reason the other way around seems more fitting.
  17. DiegoAAC
    DiegoAAC What's a Dremel?
    27 Nov 2007
    I'm guessing the card is a 1.5 GB Tesla c2000 mockup
  18. Elton
    23 Jan 2009
    Doubt it, the C2000 needed more than a single PCI-E power pin.
  19. docodine
    docodine killed a guy once
    10 Feb 2007
    Hand raised, I can't see anything under the cooler, and the 'pci-e' pins look like a single stripe of gold (though it's probably the photo).
  20. Elton
    23 Jan 2009
    Actually this is most likely the case. Although we do not know..
Tags: Add Tags
