News First GPL lawsuit filed
Discussion in 'Article Discussion' started by CardJoe, 21 Sep 2007.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. shaq
    shaq What's a Dremel?
    7 Sep 2006
    Good for the SFLC and the Busybox developers!
    Is it not enough that the developers put their effort into writing the software, and then giving it away for free?
    For the GPL to be effective, action does have to be taken, otherwise we might as well all use BSD, and that won't be beneficial to the open software movement...
  3. DougEdey
    5 Jul 2005
    Yay! I support this, they used open sourced code according to a legal license, if they don't stick to their side then they shouldn't use it.
  4. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    you can have other sources of income.... and if your code is GPL you are forced to give away the source code, if you don't want to don't register it as GPL.
  5. DougEdey
    5 Jul 2005
    The point here is that the developers gave their work away for free, why should someone else profit?
  6. DXR_13KE
    14 Sep 2005
  7. Faulk_Wulf
    Faulk_Wulf Internet Addict
    28 Mar 2006
    This is good for the GPL/GNU developers. Rules and laws are worthless if no one calls "foul" when something goes off track.
    I think that this is pretty ace. I think this situation is exactly what should happen so that companies know that they can't
    just walk all over the "little guy". Now lets just hope they win this case and set a prescedent.
  8. Scootiep
    Scootiep Minimodder
    9 Aug 2007
    This is like a community putting up a public park and someone coming in and charging admission to use the swings. Go GPL/GNU and take every last dollar from these leeches!
  9. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    tut tut tut, naughty naughty
  10. Constructacon
    Constructacon Constructing since 1978
    12 Oct 2004
    If you build on someone elses GPL product, by default yours is too and so you must follow the same terms and conditions of the GPL. Monsoon haven't done that in this case.
Tags: Add Tags
