News FSP launches the strangest 2-in-1 chassis you've seen
Discussion in 'Article Discussion' started by bit-tech, 3 Mar 2020.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Cheapskate
    13 May 2007
    Were the Bay Transformers designs really that popular?
    That thing is going to maim a lot of cats.
    The_Crapman likes this.
  3. Gomfs
    Gomfs What's a Dremel?
    9 Jun 2010
    i see potential for modding but at a 500$ pricetag that will mostly end at 800 when it reach my country it's far off what i would accept for a case that i would need to take a drill to...
    would also seen option for changing the ITX* area for something more "useful"...
    *(they could easy added mATX support with all that non-used space)
    and also something i noticed is that the "front panel" for the second system are on the rear... that doesn't seem convenient for a streaming system hiding all the connections and buttons to the side where it's hardest to reach even if it's the secondary system.
  4. The_Crapman
    5 Dec 2011
    Yeh I was disappointed in the second system layout. Why not have the left hand side as inverted ATX? They could easily have had the PSUs mounted "normally" in the bottom, at 455mm wide you could fit 3 in there!
  5. Diletta Graziosi
    Diletta Graziosi What's a Dremel?
    27 Feb 2020
    i see a lot of modding potential here
  6. frack
    frack What's a Dremel?
    28 Feb 2020
    yes, but at what price...
    Diletta Graziosi likes this.
  7. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    If this thing was 200 USD/GBP/EUR I might even consider it, just because it looks interesting. The fact they severely limited the options for the secondary system as well as that price rule this "case" out for me.
  8. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Am I the only one who sees all these cases with massive panel gaps and thinks it just looks like something made out of scraps?
    I recently saw a youtuber building in an Inwin D Frame and all I could think was "..Where's the rest of the case?" Looks like someone pulled some PVC pipe out of the scrap bin and strapped some glass and a motherboard tray to it.
  9. Mister_Tad
    27 Dec 2002
    Wow. Thats... something.
    It's definitely l33t, if nothing else.
    I think I must be losing touch with the youth of today.
  10. Diletta Graziosi
    27 Feb 2020
    that's a good point it is really expansive, and also one big of a case
    i don't really agree, there's a lot of good one like from Antec and Hydra that are good choises also for desktop use
  11. frack
    28 Feb 2020
    is that I'm getting old, but I prefer more the substance compared to aesthetics instead
    yeah but.... it's a case... why not spend those money for a gpu or custom loop instead?
  12. Jangalit
    Jangalit What's a Dremel?
    28 Feb 2020
    you are absolutely right
  13. Diletta Graziosi
    27 Feb 2020
    performance first of all, if you have spare budget for aesthetics then ok
Tags: Add Tags
