Scratch Build – In Progress future ne[]n - 100% complete!!
Discussion in 'Project Logs' started by sethnmalice, 16 Aug 2007.
  1. GAM
    GAM What's a Dremel?
    15 May 2007
    Congratulations Seth! :clap:
    You deserve the MoM nomination, well done. Keep up the good work and bring home those prizes! :thumb:
    Cheers
    GAM
  2. sethnmalice
    sethnmalice What's a Dremel?
    21 Jul 2007
    @x06jsp, thnx :)
    @500mph, thnx :) yeah i was speechless when i found out too.
    @Dean MF, thnx :), your case is completed and it too looks great, i followed your worklog :)
    @jokkos, thnx :), until they arrived ive only ever seen pics of them, i can tell you , they look much better in person :)
    @IncBot, thnx :), im totally wrapped in the sponsorship too.
    @Mankz., thnx :), id be speechless if that was the case.
    @yakyb, thnx :), i thought about water cooling it before i started the project and i did the maths and i just cant afford a decent set up of water cooling, i could do a cheap version, but its not the same, ive seen alot of mods by people in the community and im blown away by their watercooling skills, these are skills i dont have, so regretfully, no i'm not going watercooling, i dont have alot of money as is, im saving for hardware, which is almost ready to buy, nothing super duper, but itll do for the build/mod.
    @Cheapskate, thnx :), the camera vs. the sun's reflection, was just perfect for the pic, i was amazed by it when i saw the photo afterwards.
    @ComputerKing, thnx :) wont be too long.
    @TNash, ill say, its really bright, more like candy apple red, and the backing just gave it that bit extra.
    @Dean MF, I did???....woooah....ok now im speechless!!!....thnx peeps for voting for future ne[]n .....wow...im seriously speechless....thnx, really thnx :)
    @ComputerKing, thnx :) heaps!!!!
    @GAM, Im floored!!!!!!...thnx :)
    Seriously, words cant describe the feeling im feeling, thank you all for voting :):):):):):):)
  3. sethnmalice
    21 Jul 2007
    UPDATE [1st September 2007]
    So this case is coming along pretty well. I like the fact that the plan has become the reality, and that through my amazing patience its going to plan, (i really dont have alot of patience)
    A couple of things i had to fix -
    The DVD Rom bay was out just a bit, so i removed the lot and swapped it it round to the way it should have been, took the whole day to get it lined right, didnt use a ruler like should have , just line of eye sight, im 99% sure its dead on accurate.
    Also while i was measuring up the side panels to make sure they fit properly , i noticed that the whole case was leaning forward and for a few hours i just looked at it, inbetween doing something else, i couldnt place where i had gone wrong, it shouldnt be this far out, a mm or two is ok, but 1 cm is alot, so i just kept coming back to it , staring trying to figure out my mistake, then it dawned on me.
    When I lined up the DVD Rom bay frame, i levelled the base bit, it alone was pulling the case in the wrong direction , so i removed the rivets and srtaightened the case out, then resized the side panels again, nice fit, so that too is now fixed.
    I also cut out the top and bottom and corner panels, the corner panels is where im having some trouble because they are not perfectly square so when i line up the corner panels , its extremely noticable, but i cant do much about that now, so im just going to re cut the corner side pieces to how they match up with the case and prey for the best.
    I test fitted the Case Feet and they look nice, low profile too, so im happy.
    I did some other work to the side panels, this is where the lighting on the edge of the front / top / bottom and side panels comes into play (see pic below)
    Basically im going to custom a square red tube with a few layers of acrylic, then cover two sides with alu film and drill a hole for one red led in the back and into the acrylic, that will be powered by the fan bus, just some candy leds for show, should come up ok.
    This next pic is the side panel, not completed, polishing is going to render my hands useless, ive already sprained two fingers from filing, my hands are really starting to feel this, so im begining to slow down so they can recoupe.
    Might be getting the hardware earlier than expected.
    Also found out that i can get mothers alu polish in oz, which im grateful for.Ive started sanding the alu panels down, starting with 800 then 1000 finally 1200, i dont think i could manage anymore , need strength for hand polishing of the panels.
    Here's one of the panels, each side isnt the same due to each acrylic panel is different.
    Just to give you an idea.
    Well thats it for me for now, back later with some polished panels i hope :).
    Seth
  4. Teyber
    Teyber ******
    18 Mar 2007
    wow!
    i saw the mdf and thought it was going to be another mdf case, but holy sh!t! all that done with the dremel!?!?!?!??!!?!!??! wtf!
    so muhc time put into this, im guessing your still in summer?
  5. Dira
    Dira What's a Dremel?
    1 Sep 2005
    I think it's winter/spring in australia now. Am I right?
    To nice mod to say anything about it :D
  6. Guest-23315
    Guest-23315 Guest
    Basically its the opposite of what You've got, so yes.
  7. Cheapskate
    13 May 2007
    Congratulations and good luck on MoM nomination!
    Mother's polish is good for a final polish, but the DuPont polishing compound I use is a good choice in my opinion. It's kind of gritty. I use after only only 600 grit sanding, so it's a great timesaver. you could skip the 1000+ sanding stages with it.
  8. ComputerKing
    8 Sep 2006
    OH YEAH, This is what I'm talking about, This is so amazing project really, I hope that you win ;) But this is worth the time\money\work. THis is the KICKEST case that built from zero I ever saw. Can't wait to see more.
    Good luck.
  9. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    Wow this is an awesome build, I will keep an eye on this one as it progresses ^_^
  10. RebelAlien
    RebelAlien What's a Dremel?
    13 Jul 2007
    Congratulations and good luck on your M_o_M nomination! :thumb:
    You have my vote........
    subscribed...........
    RebelAlien
  11. sethnmalice
    21 Jul 2007
    @Teyber, thnx :) yup me n my trusty dremel, couldnt mod without it, has a million functions in the case modding / build world :), nope not summer, just a suinny day, i honestly dont know what season it is, but summer is coming up soon.
    @Dira, thnx :)
    @Cheapskate, thnx :), I got some mother polish, missed out on getting the compound, so thats the next to get. Goodluck to you too, your modding skills are very impressive even if u say your a cheapskate :)
    @ComputerKing, thnx :), to be in the nominations for bit-tech modder of the month has blown me away, thanks you you all, really :)
    @HourBeforeDawn, thnx:) (looking forward to your mod , nice sketchup skills you have :) )
    Rebel Alien, thnx :)
  12. sethnmalice
    21 Jul 2007
    Mini Update...
    I havnt started on the polish, i forgot something and need to pick it up tomorrow, so today I worked on the top and bottom panels, cutting them to size, afixing the billet case feet to it.
    Then worked on the top panel, originally i hadnt made a design for the top panel, maybe coz i wasnt ever going to have anything on the top, but thats now changed, but still not complete.
    future ne[]n side window panel (ready for polishing)
    other window panel (ready for polishing)
    Top Panel with proposed red acrylic window (not fully completed)
    This too will be polished, feet will stay the same and ill add el wire red to highlight the lot. (update at a later date)
    Just another shot of the feet with the case on top of it.
    There's still a whole lot to do, my left hands been playing up, but i hope to commence polishing the alu soon, i know i said the weekend, but its fathers day so polishing has been posponed for the time being.
    Seth
  13. ComputerKing
    8 Sep 2006
    WOW! THis is update! OMG NICE!! Amazing hot! KICKASS, good job. Can't wait to see more. Well done.
    You have my vote ;)
    Good luck.
  14. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    Looking great mate! Awesome! You have my vote too!!
  15. Cheapskate
    13 May 2007
    I just noticed how your main frontplate looks like some Aztec face!:hehe:
  16. ComputerKing
    8 Sep 2006
    :nono: No no that case look same the good transformers from the movie (auotmobile I think) Who knows. and the face look like the Boss or king of the good Transformers not the bad one (megatron the bad boss). That movie is so KICKASS, Same this case. Can't wait to see more.
    Good luck.
  17. Cyprio
    Cyprio G5 Supermodder
    2 May 2006
    Great mod. You have obviously put a lot of time into this both into planning and execution.
    Goof luck with the competition. :)
  18. weasal
    weasal What's a Dremel?
    22 Jul 2007
    awesome looking case so far. i envy you for being able to create this idea.good luck with mod of month
  19. THEkorean
    THEkorean 42
    10 Jun 2005
    that is hot
  20. Kyuari
    Kyuari What's a Dremel?
    30 Dec 2004
    congrats mate, just voted for you, see you around :) (Saw you posted on OCAU too ^^)
