Displays G-sync on Freesync.
Discussion in 'Hardware' started by xxxsonic1971, 7 Jan 2019.
  1. Vault-Tec
    30 Aug 2015
    Yeah it's decent once I adjusted to it being TN. I do miss the IPS of the 32", but I do like gaming at 100-140 FPS. Especially in action titles that are faster paced and helped along by the response times :)
    Thewelder likes this.
  2. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    I've just read that Samsung 4K TV's now support freesync, so they must also do Gsync maybe? If so, i dont think i'll get a monitor-just a massive samsung tv instead...Hmmm.
  3. Thewelder
    Thewelder What's a Dremel?
    27 Nov 2018
    Are 4k tv,'s 120hz/1ms yet or better?? Most are a sluggish 60hz/5ms for gaming....yet look Amazing for movies!!
    Oled tvs are but $$$$$$ :/
    xxxsonic1971 likes this.
  4. Yaka
    Yaka Multimodder
    26 Jun 2005
    freesynch works well on sammy tvs, but theres an issue it has to be direct to the tv and not through an AV amp when using the xbox one x , i am pretty sure it will be the same for connecting the a pc to the samsung screens
    Thewelder and xxxsonic1971 like this.
  5. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Some also have some panel controller limitations: you can have UHD VRR but only to 60Hz, or VRR up to 120Hz but only at 1080p. And depending on firmware you may get either a solid-on backlight (no FALD, so no HDR) or brightness variation as the FALD backlight controller is unable to cope with varying refresh intervals.
