Notebooks gap between heatsink
Discussion in 'Hardware' started by modster, 6 Dec 2007.
  1. modster
    modster What's a Dremel?
    20 Sep 2005
    I feel so bad right now. I have a 1.4ghz old laptop and bought a 1.8ghz cpu for upgrade (yeah i know...). So i opened the laptop up last night and then i realize the cpu is actually solder onto the motherboard :duh: well, so i was like, since i spent an hour opening it, maybe i should replace thermal grease just for the heck of it. So i clean everything with alcohol and applied some new AS5. When i try to put everything together, i realized one more thing. There is a gap between heat sink and the cpu.:wallbash::wallbash::wallbash: It was bridged by thermal grease before. After some googling, i realized a lot of laptops have a gap like that. My question is why is that gap even there? I am using AS5 to bridge the gap right now and its probably the worse thing to do.
  2. GoodBytes
    20 Jan 2007
    I don't even own (not yet) or opened a laptop before... (desktop computer, yes, countless times)
    But if you have space between the CPU (with thermal grease on top) and the heatsink, try putting a perfectly or near perfectly smooth coper plate of the thickness of the space gap that you have. Of course you have to to add thermal grease on the other side of the coper plate.
    So you have have
    ----- Heatsink
    ----- thermal grease
    ----- smooth polish coper plate
    ----- CPU
    Also note that you must always apply a thin (thickness or ordinary paper) layer of thermal grease and equally distributed for best results.
  3. modster
    20 Sep 2005
    thats what i thought of doing at first. but the gap is there probably for a reason. I don't want to add something that would cause harm.
  4. Jipa
    5 Feb 2004
    could it have something to do with the laptop having to withstand being thrown around? Thermal grease flexes, but CPU core/heatsink not that much. That's the first thing to pop into my mind atleast.
  5. Krikkit
    21 Jan 2003
    There's probably a gap because it was left for the thermal pad thingy, they have a thickness of a couple of millimetres quite often, and, as above, it'll withstand flexing a bit more readily. :)
  6. modster
    20 Sep 2005
    so do you guys think i should add a copper plate or find some thermal pad?
  7. cpemma
    cpemma Ecky thump
    27 Nov 2001
    It is, the best paste in the world is no good in a thick layer. As you've probably found,
    Either find a suitably thick pad, or a thin copper shim for the GoodBytes way.
