German-Project: CaseCon 'Force Cube'
Discussion in 'Project Logs' started by Capture, 7 Nov 2003.
  1. Capture
    Capture What's a Dremel?
    7 Nov 2003
    i start an experiment. i dont want use a heatercore in my system.
    the capacity of the tubes are 2,5liter =10liter !
    i use anti-corrosive 'ACfluid' in the water...
  2. lokki
    lokki What's a Dremel?
    9 Sep 2003
    So you're banking on the volume of water to dissipate the heat?? Zoinks! :eeek:
    Any watercooling experts want to comment on this? Seems dangerous...
    Looks damn cool tho :thumb:
  3. modtheplanet
    modtheplanet What's a Dremel?
    10 Oct 2003
    did you make those end caps for the tubing? or did you buy them. and from where did you get them, what are they called?
  4. MarcelloRupelli
    MarcelloRupelli What's a Dremel?
    30 Jul 2003
    Sure seems like without some sort of heat exchanger, the temp would slowly climb until something crashes. Large volume would help tho. Now, if you had a large-volume system with a large heat exchanger, it seems like you could run it fanless.
  5. Jack
    Jack Minimodder
    22 Dec 2002
    What is it with germans and modding they all seem to be so darn good at it! ive seen alot of german mods while browsing and they all have the kind of quality running through them!
    i think this case is gonna be great once finished m8 keep them pictures rolling :thumb:
  6. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    Unless you're going be running the system for short periods of time, then allowing the coolant to cool off, then turning it on for a bit more, then allowing the coolant to cool off, etc. I doubt it will work. The heat from the processor and other components has to go somewhere, so it is transfered to the coolant. The heat from the coolant doesn't have anywhere to go, other than to the components it is trying to cool.
    Someone call 8-Ball please :p
  7. Capture
    7 Nov 2003
    all the black parts 'made in germany' by Capture :D thats unique [​IMG]
    you cant buy them
  8. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Doing great man! :D
  9. modtheplanet
    10 Oct 2003
    i plan on doing a res out of 2" piping and was wondering if any know of a place i can get some end caps for the tubing. the end caps would need to be make from a plastic that can be threading easily.
  10. Xgamer
    Xgamer What's a Dremel?
    29 Oct 2003
    KICK ARSE!! :rock:
    thats one huuuge res, hope it worx out for ya
  11. Sol Badguy
    Sol Badguy What's a Dremel?
    29 Oct 2003
    wow .. those reservoirs are huge. u sure u need all that water?
    good luck with ur mod :thumb:
  12. Melov
    Melov What's a Dremel?
    30 Apr 2003
    Hallo! :blush:
    Das ist super!
  13. m3t4tr0n
    m3t4tr0n What's a Dremel?
    1 Sep 2003
    yes! that's the damn good kraut-style ;)
    schaut nicht schlecht aus :clap:
  14. ynema
    ynema What's a Dremel?
    27 Oct 2003
    This will look awesome. I've got lot's of equipment to do that type of work but you got way more skill tham me. Maybe I should learn to use it better.
    Keep up the good Work
  15. ramapoughnative
    ramapoughnative What's a Dremel?
    26 Sep 2003
    hell yeah! the more water, the better. nice attention to detail.. betcha this thing will be pretty heavy when ur done though.. :rock:
  16. lazychook
    lazychook What's a Dremel?
    21 Oct 2003
    hey capture, madass case boy! :rock:
    just a quick question tho
    in the...thrid picture, what is all of that? what are you going to use the pc board for (think its called that, correct me if im wrong)?
    good luck
  17. The_Resetter
    The_Resetter I LIKE CAKE!
    6 Oct 2003
    Holy F00ck :) nice work my neighbor ;) well we do have a saying that’s called "Duitse Degelijkheid" and in English that would be Good German Quality :)
    Wicked so far im looking forward to the next update and the end result :)
  18. taliban_raider
    taliban_raider Just some guy; you know
    28 Feb 2003
    That is nice :thumb:
    It seems if a mod comes out of gernmany it is awsome!
  19. Capture
    7 Nov 2003
    you see a Graphic LCD with controller for the printer-port.
    look at LCDStudio
  20. Nexxo
    23 Oct 2001
    Vorsprüng durch Technik... I just love that German engineering. :rock:
    If you have access to a CNC machine, you couldn't, by chance, help me manufacture some small part in aluminium for me, could you? :D
