Hardware Gigabyte G1.Sniper Review
Discussion in 'Article Discussion' started by arcticstoat, 6 Apr 2011.
  1. Morlok
    Morlok Stuck in New Eden
    14 Aug 2010
    Got as far as "Preferred Partner Price: £345.10 (inc VAT)" and stopped. No mobo is woth THAT much premium over anything else..
    "Give me your finest mobo barkeep"..
    "Certainly sire, that'll be stoopid amounts of wedge"
    "Must be pushing the bits across the busses at warp speed barkeep"
    "Indeed it does sire, USB4, Intel i9 support and UBERHDMI"
    "Give me three then barkeep"
    Just bought the Asus P8P67-M - fine enough for anything I can throw at it.
  2. kzinti1
    kzinti1 What's a Dremel?
    13 Apr 2010
    Excellent review. Exactly what I expected from this overpriced monster.
    Why do so many people consider the x58 practically dead? There's plenty of life left in this chipset and the LGA 1366 cpu's. If it's the low prices for many of the more esoteric Intel cpu's I think that's just because Intel made a serious mistake by marketing so many different speeds when just a few would've sufficed. My i7-920's are still the fastest of the lot. The one I'm using right now has been running at 4.41 GHz for well over a year. The LGA 1366 and x58 is nowhere near an EOL platform so don't bury it alive.
    Gagabyte has once again failed. Now there's a company deservious of a premature burial!
  3. SMIFFYDUDE
    SMIFFYDUDE Supermodders on my D
    22 Apr 2009
    This board just makes me giggle, I can't help it.
    Why has the "magazine" got G1 Killer written on it and not Sniper?
  4. bulldogjeff
    2 Mar 2010
    To little to late. This needed to be hitting the shelves 18 months ago to have half a chance of selling in any numbers and going toe to toe with the Rampage.
  5. Hawkest
    Hawkest I got some 4GB new RAM
    22 Jun 2009
    How much!
  6. Teh Noob Slayer
    Teh Noob Slayer What's a Dremel?
    16 May 2010
    Rumour mill is that it will be replaced by 3-6 months time.
    The new 1155 Sandy bridge i5 and i7 chips perform just as well /faster than 1366 chips (excluding 6 core chips on multi threaded apps) and they cost less. Plus they tend to overclock better than 1366 chips.
    These reasons would suggest that the x58 is gona be a dodo sometime soon.
  7. pendragon
    pendragon I pickle they
    14 May 2004
    i like the board quite a bit.. too bad it's overpriced :-/ .. would probably be a nice upgrade from my Abit IP35 Pro!
  8. JaredC01
    JaredC01 Hardware Nut
    24 Nov 2002
    It's because the LGA 2011 socket is coming out in Q4 of this year, and will be replacing the 1366 setups. For right now, 1366 is still considered the 'flagship' socket (even though performance on SDB is higher than many 1366 chips).
  9. frontline
    frontline Punish Your Machine
    24 Jun 2007
    £360? Hope you get some free stickers at least.
  10. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    block *intellitxt* there is 4 other intellitxt based services but i have not got them right now
    or as punishment use adblock and remove bit-tech.net from the allowed list as that should block all ads as well as intellitxt until they remove intellitxt from the code
    pointless board for the price
  11. Farfalho
    Farfalho Minimodder
    27 Nov 2009
    Isn't the board named G1 Killer instead of G1 Sniper?!
    £360 for a mobo is waaayyyyy ludacris!
    Edit: Went to Gigabyte and saw that every G1 brand has G1 Killer in the SB heatsink.
    Any clue about BT having the G1 Guerilla and the G1 Assassin being reviewed?
    Guess the G1 Assassin will be the top of the range since it has 16 power phase and supports 4-war Crossfire.
  12. Nature
    Nature Minimodder
    21 Nov 2005
    Paul Goodhead's math in averaging continues to blow my mind 9+9+4=22/3=7.3 yet he/you rate it as 6?? Every article he/you write has the kind of verdict on the score.
    Also, if USB 3.0 and SATA 3 are backwards compatible, why do they not replace the older ports?
  13. Unicorn
    25 Jul 2006
    Sorry to pick on your post to comment on, but it's the first one I saw when I opened the thread!
    First of all the price: If it's genuinely worth £360, I will pay it. I've bought a board or two in my time that cost £350 or slightly north of it, and at the time those were genuinely top end, industry leading, brand new technology carrying boards. This however, as many people have said, is just another X58 motherboard. There's barely any point in me going past that but I've started now so I will continue. Yes, it's just another X58 board. It doesn't matter what new features they've added to it or what amazing accessories they've bundled with it, it's not worth £360 of yours or my money. I wouldn't go so far as to call Intel X58 or the 1366 socket obsolete, but it's certainly ageing and well on it's way out. There are an almost silly number of really good enthusiast grade X58 boards to choose from at the moment and many of them cost less than this one and don't look nearly as stupid.
    That's my next problem with this board, and the rest of the G1 range. It doesn't matter who they were, what positions they held or even if it actually was a good call as far as marketing goes, I would like to get my hands on the idiots from Gigabyte who suggested, agreed with and implemented the idea of having the heatsinks shaped like magazines. These are the stupidest looking motherboards I have ever seen. Bar none. I refuse to buy or sell any of them based on that alone. To put it quite bluntly they look like tacky ****.
    As far as performance goes... really? It's a fat load of "meh". I only skimmed through the review but a board that I have which is fast approaching a year old matches and in some cases outperforms the G1 Sniper, and it cost slightly less... a year ago.
    I just don't understand this at all. I could see through it if I thought it was actually going to be popular. Bought by silly gamers with more money than sense, but then that's their decision... but I really don't see these boards being the big success that Gigabyte think they will be.
    Antec did it to me with a few of their gamer series case designs, Seagate did it a long time ago (and we all know why) and Gigabyte have done it in the past with reliability problems too (I'm talking 6 years ago btw). They've just done it again... I've been put off and disappointed by an Industry leading manufacturer.
    Well played Gigabyte...
  14. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    The overall score isn't an average of the breakdown scores, it's a weighted calculation as some factors are more important than others.
    To make this clearer, we're updating the bit and CPC scoring system at the mo, ETA soon :clap:
  15. psychoti
    psychoti What's a Dremel?
    6 Mar 2008
    nothing personal but from the 1st time that i saw it looks ridiculous!
  16. jimmyjj
    jimmyjj Minimodder
    20 Jul 2010
    Coming next. Heat sinks shaped like boobs.
    Not sure if this would be good or bad thing. Perhaps the nipple naturally has a large amount of surface area to internal volume and would actually make the most efficient design for a heatsink.
    Imagine a board with boobs for heat sinks, but that actually turned out to be the worlds greatest overclocker.
    Good lord.
  17. Jasio
    Jasio Made in Canada
    27 Jun 2008
    This motherboard is in a glass display at NCIX in Vancouver; the reasoning? It looks nice, and nobody will ever buy it at that price so might as well make it a wall ornament.
    Sounds 'bout right to me.
  18. wiggles
    wiggles Minimodder
    9 Jun 2010
    "This is because £360 is a hell of a lot to pay for a motherboard, especially one that only performs ever so slightly better than boards that cost half the price"
    Could try going lower than a 4 for value once. Never know, you might like it.
  19. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    £360 for a mobo :jawdrop:
  20. Elton
    23 Jan 2009
    If the conversion rate makes any sense, I could buy myself an Entire i5, or i7 setup with that kind of coin.
Tags: Add Tags
