Hardware Gigabyte Radeon HD 4850 1GB (GV-R485MC-1GH)
Discussion in 'Article Discussion' started by Tim S, 28 Nov 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. The boy 4rm oz
    10 Apr 2008
    The cooler does look cool (pardon the pun lol). I have always admired Gigabyte for their passive cooled designs, the best IMO.
  3. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    very nice indeed.
    Can you post pictures of your test setups with and without fan? I'd really like to know how close they both are to my case design so i know what to expect. :)
  4. Sim0n
    Sim0n rm -rf /
    14 Dec 2001
    Would you be able to comment also, if the card is "far off" being a reference design.
    I ask, because it could make a much better choice for watercooling, with the power/heat saving modifications to the power circuits. but if by doing that they have "blocked" most full cover waterblocks, that would be a bad thing :p
  5. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    I have one question:
    Does the decline in power consumption has anything to do with the absence of active fan(s) on the board?
  6. Tim S
    Tim S OG
    8 Nov 2001
    here's with the makeshift "side panel" fan... every other card is tested without that fan there.
    It'd have a small affect... probably less than 2W.
  7. Xtrafresh
    27 Dec 2007
    thx Tim, that's making things a lot clearer. I think this card is very suitable for me. I integrated my PC in the desk (project unfinished :( ) and the sound of my 8800 GTS 640 is really starting to bug me. Plus this looks better :D
  8. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    How well would this card handle TES4 Oblivion at 1920x1200, given a reasonable CPU (Quad Core)? 40-60 Frames?
  9. Tim S
    Tim S OG
    8 Nov 2001
    I'd say Fallout 3 is more intensive, but based on the same engine... you should be able to play at 1,920 x 1,200 fine with a bit of AA to boot.
  10. airchie
    airchie What's a Dremel?
    22 Mar 2005
    The 2nd paragraph in the "final thoughts" section doesn't make sense...
    Nice card though. :)
  11. Tim S
    Tim S OG
    8 Nov 2001
    proof reading fail, thanks.
  12. mrb_no1
    mrb_no1 Pie Eater
    15 Sep 2007
    love it, i absolutely love it. a completely silent solution that allows performance. if i had a decent job i'd buy one for the htpc i want to build for my imaginery 50 inch 1080p tele. ho hum, to the gym to earn that job :p
    peace
    fatman
    p.s nice review as always tim, bla bla bla
  13. lp1988
    lp1988 Minimodder
    24 Jun 2008
    getting a 4850 passivly cooled... that is one hell of a job,
  14. PhenomRed
    PhenomRed What's a Dremel?
    3 Dec 2007
    If its not held on with tape, its not worth putting there :p
  15. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    hmm me thinks I see the card thats going to replace my current 4850 for my HTPC, no worries the current 4850 with the noisy fan will make a new home in my brothers rig which will be a nice upgrade for him.
  16. naokaji
    naokaji whatever
    8 Dec 2006
    The drop in power consumption seems a bit too good, they might not just redesigned the pcb, but also lowered the gpu voltage a tad, not like that would be a bad thing if it still works afterwards though.
    1GB Ram on a Midrange graphicscard? seems a bit of a waste to me, no real performance benefit unless you have a monitor that can run at 1,920 x 1,200 or higher, which means 24" or bigger, however, if you have a 24"+ monitor, you will most likely have the cash for a 4870, GTX280 or 4870x2 anyway.
  17. Scootiep
    Scootiep Minimodder
    9 Aug 2007
