A/V Good Monitor With Component
Discussion in 'Hardware' started by TheSaladMan, 29 Mar 2007.
  1. TheSaladMan
    TheSaladMan What's a Dremel?
    15 Sep 2006
    Hey all
    Was just wondering if anybody knew what good monitors around the 20" size there are at the moment which have Component, VGA and DVI and good picture quality. The main reasoning behind this is that I want a monitor which I can hook my PC, PS3 (When I get one) and my 360 up to at the same time.
    Thanks :D
  2. DougEdey
    5 Jul 2005
  3. sandys
    sandys Multimodder
    26 Mar 2006
    no component on that.
  4. TheSaladMan
    15 Sep 2006
    Actually if you check the Asus Website you'll find there is component, Scan just haven't said so.
    Cheers Doug
  5. whisperwolf
    whisperwolf What's a Dremel?
    1 Sep 2004
  6. kingdavies
    kingdavies Minimodder
    29 Aug 2004
    I wouldnt get any monitor that isnt HDCP
  7. GoodBytes
    20 Jan 2007
    I want the ASUS monitor so much... the only problem is the dam speakers... WHY?!?!
    Altho it's nice, I'm sure they are crappy, like all monitor speakers.
    Sure I don't have to plug them, but then it feels weired.
    Is it all in aluminum?
