Graphics Green lines on startup
Discussion in 'Tech Support' started by JitsuSparty, 5 Oct 2014.
  1. JitsuSparty
    JitsuSparty Member
    25 Apr 2011
    I turned on my pc earlier to be confronted with a lot of green lines and artefacts as it booted:
    it is a GTX 670,
    any ideas on what I can do or is it screwed?
  2. JitsuSparty
    JitsuSparty Member
    25 Apr 2011
    ok more info - swapped in an old card and the system started fine... guessing it is the gfx card then
  3. GoodBytes
    20 Jan 2007
    Yea, your graphics card is faulty. Those are the signs. :/
  4. JitsuSparty
    JitsuSparty Member
    25 Apr 2011
    hmm guessing as the old card works it cant be power supply... well this sucks :p
  5. GoodBytes
    20 Jan 2007
    If it was the power supply, the system would shutdown when you play a game.
    Here you are at idle.
  6. JitsuSparty
    JitsuSparty Member
    25 Apr 2011
    Well RMA process begun with EVGA, will update this thread with progress if anyone reads :p
  7. chilliewillie
    chilliewillie New Member
    14 Apr 2014
    wel rma it or bake it
  8. Deders
    Deders Well-Known Member
    14 Nov 2010
    Does it happen every time? Sometimes I get something similar at the very top of my monitor. I switch the monitor off and on again and it goes away.
  9. GTIgeneral
    GTIgeneral Member
    31 Jul 2014
    Just had the same thing on my graphics card, a GTX560ti, had no picture when my pc was plugged into my AV system, so i plugged it straight into a TV and had the same type of screen artifacts and lines as you.
    I tried the DVI port on my graphics card and it works fine, turns out the HDMI port was knackered, its the second 560ti Ive had that has developed a problem with the mini HDMI port
  10. JitsuSparty
    JitsuSparty Member
    25 Apr 2011
    Update - received a refurbished card from EVGA - put it in my system and there was no green lines (YAY), but idling at 65 deg :(
    I then loaded a game (Civ V) and it decided to crash my system, with the fans on the card blowing hard.
    guess time to talk to EVGA again
  11. Deders
    14 Nov 2010
    Is it clocking down properly when idle?
  12. JitsuSparty
    JitsuSparty Member
    25 Apr 2011
    on start it reads 67 degrees... doing nothing evga reads 38 - 40 (watched for 1 min)
    refreshing my windows experience (only thing I thought of) it goes straight up to 102 degrees and the system restarts
