Graphics GTX 480 Appreciation Society
Discussion in 'Hardware' started by Blogins, 15 Apr 2012.
  1. Guest-16
    Guest-16 Guest
    Anyone want an MSI GTX 480 Lightning? Thinking of upgrading mine. Never OC'd, stock cooler.
  2. LennyRhys
    LennyRhys Oink!
    16 May 2011
    Depends how much you want for it ;)
  3. Elton
    23 Jan 2009
    I am tempted to put one of these babies under water and run it. But Given my limited budget and my aversion to using Watercooling for now. (Mainly due to budgetary issues and the fact that I'd have tear my case apart) I'll hold off for a long long time. :(
  4. Guest-16
    Guest-16 Guest
    What are they worth now? 240? :D
    It's got all the OC stuff on it and the TwinFrozr II cooler.
  5. The_Crapman
    5 Dec 2011
    @LennyRhys, What is a 480SE? I remeber there being a 460SE which had less shaders than the standard 460s. Is that the case with the 480 too?
  6. Parge
    16 Jul 2010
    Special Edition - think it just has a aftermarket cooler!
  7. LennyRhys
    LennyRhys Oink!
    16 May 2011
    The "SE" is Gigabyte's own designation of Special Edition because the card has a non-reference PCB which is far superior to a standard 480 because it has a crazy 12 phase power design (10 for the GPU and 2 for the memory). And, as Parge said, it also has a very nice aftermarket cooler. ;)
    The PCB is exactly the same as Gigabyte's SOC version of the 480. It's freaking awesome...
    AHAHAHAH 240 pence maybe :D
  8. Parge
    16 Jul 2010
    You know why people do watercooling - Because it looks awesome, you can get higher OCs, but most of all to keep noise levels and temps down. With the 680 4GB Super-Duper Edition there isn’t much point, the card is already silent, chews through everything and thanks to clever software and a smaller process technology, already runs lovely and cool. However it’ll also cost you an absolute packet.
    As far as I’m concerned the GTX 480 is the ideal card for watercooling. The amount of power it delivers was never in question – its top draw - but the reason it’s not an all time classic like the 8800 GTX is that it wasn’t as ‘refined’. It achieved its monumentus power output through brute force rather than tuning, and as a result is hot, loud and power hungry. But, these are the exact reasons why it makes such a good case for itself when it comes to watercooling, as that immediately eliminates the first two of those problems outright, and as Blogins has already proved, the last of those issues is overstated, a good quality PSU will capably run one or even two 480’s.
    I say pick up a second hand block and backplate and do it. Oh, and did I say it looks awesome? Because it looks awesome.
    Elton likes this.
  9. Guest-16
    Guest-16 Guest
    200 quid then? :D It only needs a core block because it has a baseplate for all the VRMs and memory. I did that for ~8 months!
  10. The_Crapman
    5 Dec 2011
    Does it have the the windforce 3 cooler and the led's on the back? or was that on the soc only?
  11. Xenon_MD
    Xenon_MD What's a Dremel?
    16 May 2012
    Nice to see one of my fav cards of all time getting some lovin' :)
    Run mine at defaults currently - with a Zalman VF3000 iirc it dropped temps by a good +20% in my setup over the OEM cooling.
  12. The_Crapman
    5 Dec 2011
    I'm sorry to report that my evga gtx 480 with ivy vision cooler will be on the marketplace in a few days time, once my new gfx card arrives. In the words of the great rolf harris, can you tell what it is yet?
  13. The_Crapman
    5 Dec 2011
    If anyone fancies another 480 for SLI goodness let me know. Members of the 480 appreciation society can have first dibs on it :) Will be wanting £130ic p&p.
  14. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Traitor! Also is that a Gigabyte GTX 670 by any chance?
    Yet my reference PCB clocks higher! Sorry, couldn't resist! :D
  15. The_Crapman
    5 Dec 2011
    Nope guess again! ;-p
  16. Blogins
    3 Aug 2010
    Hey everyone, look at my pimped out GTX 480! :D
  17. mikeyman198
    mikeyman198 Lets pretend this is hilarious.
    12 May 2011
    Why is there a pipe going into your PSU :confused:
  18. Teelzebub
    27 Nov 2009
    It's a water cooled PSU :worried:
  19. Blogins
    3 Aug 2010
    Acrylic pipe that provides support for the heavy EK-FC480 GTX water block.
    Works a treat and completely stole the idea from a fellow Bit-Techer! :D
  20. The_Crapman
    5 Dec 2011
    Nice! :D do my eyes decieve me or is that the icy vision in the bottom right?
