Case Mod - In Progress H.A.F. REBORN - Completed!
Discussion in 'Project Logs' started by neSSa, 12 Oct 2015.
  1. neSSa
    neSSa Multimodder
    11 Aug 2014
    Assembling the front panel and 360 radiator bracket.
  2. neSSa
    neSSa Multimodder
    11 Aug 2014
    360 radiator and switches perfectly fits :)
  3. neSSa
    neSSa Multimodder
    11 Aug 2014
    bottom, there is space for accession drain fitting...
    fan can be installed and the inside of the front panel without interference...
    [​IMG] [​IMG]
    Fans can also be installed on the front side of the front panel and there are the holes for cable routing ...
    [​IMG] [​IMG]
  4. neSSa
    neSSa Multimodder
    11 Aug 2014
    preparation for painting...
  5. neSSa
    neSSa Multimodder
    11 Aug 2014
    paintwork...
  6. storm-83
    storm-83 Minimodder
    7 Nov 2014
    hot damn this is exciting!
    i miss my haf stacker 832 sooooo much, love the HAF cases
  7. neSSa
    neSSa Multimodder
    11 Aug 2014
    Thnx, brushed aluminum foil...
  8. neSSa
    neSSa Multimodder
    11 Aug 2014
  9. neSSa
    neSSa Multimodder
    11 Aug 2014
    Gluing and trimming aluminum foil...
  10. neSSa
    neSSa Multimodder
    11 Aug 2014
    motherboard try finished :)
  11. neSSa
    neSSa Multimodder
    11 Aug 2014
    360 rad grill, hmmm dilemma, what is your choice?
  12. Shurika
    Shurika Minimodder
    9 Mar 2012
    Choose 5
  13. Vault-Tec
    30 Aug 2015
    5 breaks the symmetry. I would go with 2 or 1.
  14. TeofiloDesign
    TeofiloDesign What's a Dremel?
    8 Sep 2015
    2 or 6. My favourite one is the 6th
  15. neSSa
    neSSa Multimodder
    11 Aug 2014
    Thanks guys , and my idea was 1 or 6, I did not say that it will go under the grill steel mesh of hexa so you will be strong enough , I'm now on the seventh model will be similar to the sixth , when it was over I'll ask you for the feedback :)
    Cable holders on motherboard try...
  16. neSSa
    neSSa Multimodder
    11 Aug 2014
    Ended with a seventh model , which consists of three parts , I think this is the final version :)
    I want to show the tree parts grill with the MSI logo, but MSI unfortunately did not respond to a request for sponsorship :(
  17. neSSa
    neSSa Multimodder
    11 Aug 2014
    today a little bit of manual work, I had to remove the side perforated sheet to 360 grill fit
    and prepares the rear cover...
  18. neSSa
    neSSa Multimodder
    11 Aug 2014
    here's where we are with the works...
  19. neSSa
    neSSa Multimodder
    11 Aug 2014
  20. neSSa
    neSSa Multimodder
    11 Aug 2014
    To introduce you to another feature, the CPU hole on MB thry is done so that it can accept the 120mm fan that can be moved an inch, depending on the position of the socket. This provides better cooling of the socket and the CPU!
