Hardware list
Discussion in 'Hardware' started by Noobkiller, 16 Aug 2007.
  1. Noobkiller
    Noobkiller What's a Dremel?
    11 Jun 2006
  2. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    going to want a better wireless card than that aren't you?
    otherwise this looks like some good stuff
  3. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
    Not a bad build, although I have two suggestions. It might be better for you to go with a dvd-rom drive for approx. $3 or 4 more than the CD-rom you have selected. They generally have no problems reading both dvds and cd-roms and thus will be more versatile. Second, I wouldn't trust my builds with a psu such as the one you have picked. Power supply is not the place to skimp in a build, in particular with the wonderful video card (8800 GTS) you have selected. I'm certain everyone could make recommendations, but it might be good to state your dollar limit. Also, what are your plans with this build and do you plan to overclock at all?
  4. Brooxy
    Brooxy Like a boss (but not a boss)
    20 Apr 2006
    As with the previous comments, about the PSU, DVD and WiFi...and one more bit to add. The speakers? Cheapness in the speakers is something you want to avoid, if you want decent sound quality. How much extra could you add to the budget? (if anything)
  5. SanDmaN
    SanDmaN Minimodder
    11 Mar 2004
    I notice you are buying from a few shops, is the money you save by buying from other shops greater than the extra costs on postage? Also you seem to have chosen the basics of everything apart from the gfx card. Maybe you should look into downgrading on that and maybe upgrading of other items like cpu / ram / psu etc. It's all well and good having a top gfx card but if the rest of the system isn't up to the job then you'll not be getting the full benefits of the card.
    Also you'll find a lot of games are on DVD now so you should get a dvd-rom at least (writers are dirt cheap now too) and also you have no fans for cooling too. i'd atleast have 1 input and 1 output just to keep everything nice and cool. Also there's no monitor......
  6. Noobkiller
    11 Jun 2006
    Okay, 1) Where I can find a DVD Rom drive for only $3 to $4?
    2) What power supply do you reccomend?
    I have $820 bucks now, (thx to my blog, Pariah's Guild) and type of speakers do you reccomend?
    My parents are buying the monitor. I can't downgrade on the processor because I have an Nforce 4 mobo (socket 939) that haven't been used.
  7. Noobkiller
    11 Jun 2006
    What wireless card do you reccommend?
  8. Noobkiller
    11 Jun 2006
    sorry, must of misread. I'll replace that cd-rom drive with a dvd rom drive. Might be a little more though
  9. Noobkiller
    11 Jun 2006
    well, it looks like I'll be doing most of my shopping with Newegg.com. The only thing I'll be buying froma different store is VIsta and the heatsink.
  10. Krikkit
    21 Jan 2003
    Well for a wireless network adapter if your mobo already has a spare PCI-e slot, I can highly recommend an Abit Airpace (got one here). Brilliant, no-fuss adapters.
    If you're after USB, then I've had a decent experience with this Belkin one.
    Unless you really won't use it, I'd spring the extra few dollars for a DVD-RW too, they're not that expensive these days.
    One more thing - PLEASE GOD replace that PSU. I've seen so many builds fall apart at the seams because the PSU gets skimped on. Even if you have to jump down to an X1950 XT from that 8800GTS, please get a decent, big-brand PSU. We're talking $100-worth of decent PSU here. Something about 480W should do you fine.
    Big brands would be: Corsair, Tagan, Hiper, PCP&C, OCZ, Antec, Seasonic, Silverstone and Zalman. Anyone else in newegg's manufacturer list you can forget (or near enough, I could've left out a couple of decent brands pending BBQ's pwn knowledge of PSU's).
    I can't say this enough times. DECENT PSU.
  11. Noobkiller
    11 Jun 2006
    to be honest Krikkit, I DON'T TRUST USB WIRELESS NETWORK ADAPTERS. Every USB Wireless Network adapter I got, it took 3 months for it to die on me. So, to avoid any aggrivation, I'm going with a PCI slot one.
    THX for the major help guys! I'll keep asking my build related questions in this thread
  12. Krikkit
    21 Jan 2003
    Fair enough, I really recommend that one though, a mate of mine's had one for a couple of years now without a single problem, ever.
    Please, let me sleep tonight knowing that you'll change that PSU. Please.
  13. Noobkiller
    11 Jun 2006
  14. kingdavies
    kingdavies Minimodder
    29 Aug 2004
    You need DDR ram not DDR2. The second PSU is better, if you want one of the best graphics cards then you need one of the best PSU's!
  15. Noobkiller
    11 Jun 2006
    thx for the heads up man
  16. Krikkit
    21 Jan 2003
  17. Noobkiller
    11 Jun 2006
  18. Noobkiller
    11 Jun 2006
    :eyebrow:
    this has 430 watts
  19. kingdavies
    29 Aug 2004
  20. Krikkit
    21 Jan 2003
    It should be plenty tbh, as long as you don't go mad with bucketloads of extra drives and peripherals. :)
    Seasonics really are very good, they often underestimate how much a PSU can take. :)
