Modding Heat transfer with lacquer coated rads
Discussion in 'Modding' started by The_Crapman, 20 Jun 2012.
  1. The_Crapman
    5 Dec 2011
    I want to strip the paint off some rads to have a bare metal finish on them, but don't want them to dullen over time. If i spray them with a lacquer, will that reduce the heat transfer too much?
    I could ensure i used a very thin lacquer to lessen the effect, but am worried that it will all but stop any heat dissipation from the fins.
  2. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    Probably no worse than the paint that's already on them.
  3. The_Crapman
    5 Dec 2011
    Good point!
