Hi boys. I would need one suggestion of yours::* I would want to put under liquid, my Vga: Sapphire Ati AMD Radeon HD 7950 with Boost Core 850/925MHz Memory GDDR5 5000MHZ 3GB 2xDVI HDMI DP SKU#11196-19-20G If possible I would like to put a Full Cover in plexyglass... Example as this:* Which model should I buy? Thanks...
Hi there. That's an ekwb water block, but they didn't make one compatible with your card. The pcb on your model is a custom one and there aren't any full cover blocks for it unfortunately.
With a core only block, that's about your only option. I wouldn't advise doing it, though. The rest of the card needs cooling too, especially the VRMs! Leave it on air, or change it for one that can be cooled with a full block.
