Build Advice Help with choosing new CPU
Discussion in 'Hardware' started by AT0MAC, 22 Feb 2015.
What would you choose?
  1. AMD 860K w ASUS MB
    1 vote(s)
    6.3%
  2. Intel G3258 w ASROCK MB
    0 vote(s)
    0.0%
  3. Intel i3 4160 w ASUS VanGuard MB
    3 vote(s)
    18.8%
  4. Intel i5 3470 w old MSI MB
    12 vote(s)
    75.0%
  1. AT0MAC
    AT0MAC Pirate Captain
    8 Jun 2008
    I have more than one PC in the home, but only one of them have Windows - my gaming rig.
    Lately it has started to show signs of needing an upgrade for more power.
    I need a better CPU.
    Right now I have a very cheap option installed that has actually given me a LOT of bang for the buck, so Im seeking the same kind of experience without needing to do a bank heist.
    I have a Pentium G2030, socket 1155.
    I am going to keep my Intel 520 240GB SSD, ASUS GTX 660 graphics card and my 8 GB of ram.
    My motherboard is a MSI Z77MA-G45 with a Noctua NH-U12P SE2 CPU cooler.
    I have found the following candidates:
    A
    AMD Athlon II X4 860K CPU
    & ASUS A68HM-PLUS motherboard
    ...the cheapest upgrade on the list :rock:
    4 cores and a good OC potential on a great motherboard, good upgrading potential.
    or
    B
    Intel Pentium G3258 CPU
    & ASRock Z97M Anniversary motherboard
    ...2nd cheapest :thumb:
    A fun dual core CPU on a cheap MB with lots of potential, can keep it for later upgrades to i5/i7.
    or
    C
    Intel Core i3 4160 CPU
    ASUS VANGUARD B85 motherboard
    ...most expensive on the list :naughty:
    GREAT motherboard were I dont need to think about K or non-k CPU as it can not OC, good starter CPU w dual core.
    or
    Keep my S1155 motherboard and install a Intel Core i5 3470 CPU
    ...almost as expensive as the one above :idea:
    Gives me a real bump now but will be harder and harder to upgrade as S1155 CPUs are starting to disappear because of S1150 and newer
  2. elise_s1
    elise_s1 What's a Dremel?
    26 Jan 2015
    1155 used 4 core CPU
    there is an used one (i5 3340) sold by Amazon for less than 100£
  3. jinq-sea
    15 Oct 2012
    FWIW I'd buy a used 3570k or 2500k and clock it later if necessary!
    Sent from my iPhone using Tapatalk
  4. Shirty
    18 Apr 1982
    As above. Pick up a 2500K used for €90 or so and clock it up, it'll be a fair bit quicker than any current i5 at stock and a lot quicker in games.
    Until Intel's architecture makes a leap the Sandy/Ivy big boys will hold their own.
  5. AT0MAC
    8 Jun 2008
    Actually a friend of mine just offered me to buy his i5-3570K for £90, is that a good deal?
  6. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Sounds reasonable to me.
  7. jinq-sea
    15 Oct 2012
    pull that trigger! :)
  8. AT0MAC
    8 Jun 2008
    Well, I went to bed and sent my friend a message in the morning, by then it was sold on ebay so no luck there :(
    Instead I just found a guy who is willing to sell me a standart i5 3470 for £60, should I get that deal or try to find a K model instead (2500, 2600, 3570, 3770)?
  9. jinq-sea
    15 Oct 2012
    Personally, I'd avoid a non-K chip and get a K model. It's clockable, so it should last longer! :thumb:
  10. AT0MAC
    8 Jun 2008
    It seems to be a bit hard to find a good deal on k cpus for s1155 these days, so im thinking i could get this quad core non k as a temp solution?
  11. jinq-sea
    15 Oct 2012
    Depending on how urgent the need is, you might find something on the MP here, and hopefully a seller that will ship to you?
    Else, a non-K would be a big jump up from the Pentium!
  12. AT0MAC
    8 Jun 2008
    ok, I did not take the 3470 either, am instead waiting to get a good deal on a K CPU :) thanks for all the advice
  13. alfizzle
    alfizzle Ooh aah just a little bit..
    3 Apr 2013
    Id go for a used 2500k for around £90~, you could clock it in the future and imo its a very sensible choice, although im on and amd system i don't recommend changing from intel to them.
  14. Harlequin
    Harlequin Modder
    4 Jun 2004
    get that non K and a board , if it somehow doesn't have enough cpu p[ower for you then look for a k later
  15. silk186
    silk186 Derp
    1 Dec 2014
    Just be patiant and wait for what you really want.
    I'm currently in the same boat- waiting for a CPU/MB combo
  16. phem0r
    phem0r What's a Dremel?
    14 Feb 2011
    As others have said, i'd wait and look around for a 2500k
  17. AT0MAC
    8 Jun 2008
    Well I can´t seem to get any luck with finding a good old 1155 K CPU for a reasonable price right now, so instead I jumped the gun and found a ASUS MAXIMUS V GENE motherboard!
    £120 is most likely not the best price, but that board seems to be in almost higher demand than the K CPUs, so I got it on a buy it now deal on eBay...
    Am I not right about this being a kick-a// board for a K CPU?
  18. Arboreal
    21 Jan 2011
    Yes, Maximus V Gene is a great board, good choice. I did look at getting one, but am now running ITX, which means I can have a smaller & lighter rig (found a nice used Maximus VI Impact).
    Like Hrlequin has already said, the non K i5s are great, the i5 3470 on Z77 in my work PC is very capable.
    The K overclocking is the bonus on top of a very capable chipset.
    Good luck with finding a good CPU
  19. AT0MAC
    8 Jun 2008
    Today I won a eBay auction with a 3570K! I had not noticed the 2xxx series only support PCIe 2 and not 3, as all new graphics cards do... So now I am waiting for my new CPU and MB and will boost my PC dramatically! :clap:
    Thanks for everybodys help
  20. Arboreal
    21 Jan 2011
    Nice one! No limits with i5 K and ROG goodness.
    Enjoy :D
